    How to use the new UserData Button?
    12 Posts 0 Posters 1.4k Views
      On 27/09/2014 at 14:35, xxxxxxxx wrote:
      Hello everybody,
      does anyone know how to work with the new UserDat Buttons?
      greetings
      rown
        On 13/10/2014 at 02:37, xxxxxxxx wrote:
        I would like to know this too 🙂
          On 13/10/2014 at 05:39, xxxxxxxx wrote:
          from the plugin side it could be set and used like this:
          def AddUserdata(self,op) :
            rootGroup = c4d.GetCustomDatatypeDefault(c4d.DTYPE_GROUP)
            rootGroup[c4d.DESC_NAME] = "Button_Group"
            rootGroup[c4d.DESC_SCALEH] = False
            rootGroup[22] = 2 #two colums
            rootGroup[c4d.DESC_PARENTGROUP] = c4d.DescID(0)
            op.AddUserData(rootGroup)
            button= c4d.GetCustomDatatypeDefault(c4d.DTYPE_BUTTON)
            button[c4d.DESC_NAME] = "BUTTON"
            button[c4d.DESC_CUSTOMGUI] = c4d.CUSTOMGUI_BUTTON
            button[c4d.DESC_PARENTGROUP] = op.GetUserDataContainer()[0][0]
            UsdataDescId=op.AddUserData(button)
          def Message(self, node, type, data) :
                if type== c4d.MSG_MENUPREPARE:
                    AddUserdata(self,node)
                if (type == c4d.MSG_DESCRIPTION_COMMAND) :
                    id = data['id'][0].id
                    if(id == 700) :
                        print id
                        print data
                        print "button pressed"
          Martin
            On 13/10/2014 at 05:52, xxxxxxxx wrote:
            Thanks for the reply.
            Is there a way to get to the button in a python tag, like with other user data?
            I tried:
            print op.GetObject()[c4d.ID_USERDATA,1]
            in a python tag, but that returns None
              On 14/10/2014 at 01:14, xxxxxxxx wrote:
              unfortunatly I don´t have a solution for this.
              It seem´s logical to me that op.GetObject()[c4d.ID_USERDATA,1] does´nt work.
              A button message is´nt the same, as a stored ud value.
              It´s indeed interesting how to handle this.
              Anyone?
                On 14/10/2014 at 01:32, xxxxxxxx wrote:
                +1 on the interested to use this in a scripting context.
                  On 14/10/2014 at 06:05, xxxxxxxx wrote:
                  I think I may have figured out where the buttons are meant to be used. The new 'Interaction tag" in R16 has a message function you can activate and I managed to get it to give me consistent numbers when using UserData button presses.
                  def message(id, data) :
                      if id == 18: # Don't know why 18 yet :(
                          for i in data['msg']: #seems to be the consistently changing thing
                              print i[c4d.DESC_NAME] #the number stays [c](https://www.google.com/search?client=safari&rls=en&q=consistent&ie=UTF-8&oe=UTF-8)onsistent aligning with different button presses
                  Let me know if anyone has more light to shed.
                  Adam
                    On 15/10/2014 at 14:36, xxxxxxxx wrote:
                    It seems we are able to use message function in python tag now.
                    PythonTag with UserDataButton and following lines...
                      if id == 17:
                          print "UserData-ID: ", data["descid"][1].id
                      pass #put in your code here
                      On 15/10/2014 at 23:56, xxxxxxxx wrote:
                      thank you both Adam and rown.
                      For the idea and the proper solution at the end.
                      This works!
                      Best wishes
                      Martin
                        On 16/10/2014 at 00:34, xxxxxxxx wrote:
                        Many thanks!
                          On 16/10/2014 at 01:47, xxxxxxxx wrote:
                          #define MSG_DESCRIPTION_CHECKUPDATE               17 ///< Allows elements to determine the type of refresh after a parameter has been changed in the Active manager.
                          #define MSG_DESCRIPTION_COMMAND                   18 ///< Sent by for example @em BUTTON description element. @correspondingData{DescriptionCommand}
                          id == 17 - rown, you simply check out dirty of gui?! But if udata is at pyTag...
                          if udata at host op( _op.GetObject()_ ), thats question.
                          I tried through c4dAtom.Message...freeze c4d or got shutdown
                            On 17/08/2015 at 08:48, xxxxxxxx wrote:
                            Just for completeness, in this thread there's now a more complete example, how to use User Data buttons in the Interaction Tag.
