    tagplugin workflow
    4 Posts 0 Posters 422 Views
      On 27/09/2014 at 06:10, xxxxxxxx wrote:
      I have a tagplugin with userdata defined in Init(self, node).
      Of course only when if (len(node.GetUserDataContainer()) == 0).
      What I see happening is that for every change in the userdata Init(), Execute() and Message() are triggered.
      So, what is the best place to process user input?
      For example when a slider in Userdata is changed?
      I guess it should be Execute(). But Execute() is called in a thread context. and thus not everything is possible. For example gui.RenameDialog() is not possible "invalid cross-thread call".
      I can not use Message() because I do not know which message should I handle.
      It is not MSG_DESCRIPTION_COMMAND or MSG_DESCRIPTION_EDIT_ENTRY.
        On 30/09/2014 at 07:37, xxxxxxxx wrote:
        MSG_DESCRIPTION_COMMAND is triggered when your tag has a button that is pressed - that is the best location where to open GUI commands.
        Never call any blocking operations in TagData.Execute. Imagine you press play and a dialog opens for every frame.
        Cheers, s_rath
          On 30/09/2014 at 10:27, xxxxxxxx wrote:
          But how can I detect a slider interaction with MSG_DESCRIPTION_COMMAND?
          There is no data or id.
          What´s about
          if (type == c4d.MSG_DESCRIPTION_USERINTERACTION_END) :
          all ud values must be storerd in a variable and be compared for any userinteraction.
          Is this the best way to handle this?? Or just cumbersome?
          best wishes
          Martin
          edit or if it is a slider that should be updated in realtime
          if (type == c4d.MSG_DESCRIPTION_CHECKUPDATE)
