    Bitmap shader with mov file
    2 Posts 0 Posters 198 Views
      On 25/09/2014 at 17:32, xxxxxxxx wrote:
      Hi there,
      If I check the channel data for a certain shader within init render struct, and the bitmap inside the shader is a mov file, I´ll  get the wrong result for the actual frame.
      If I use the bitmaps.MovieLoader() and check for
      ok, image = ml.Read(doc.GetTime().GetFrame(doc.GetFps())).
      I´ll get the right image.
      But how can I update the shader for the render struct?
      Or is there any other routine to solve this?
      Thanks in advance for any help.
      Martin
        On 29/09/2014 at 07:03, xxxxxxxx wrote:
        is there really no other way than setting up
        frame=doc.GetTime().GetFrame(doc.GetFps())
        Bitmap[c4d.BITMAPSHADER_TIMING_FROM]=frame
        with all the calculations that are needed to change the frame value properly
        Bitmap[c4d.BITMAPSHADER_TIMING_MODE]
        Bitmap[c4d.BITMAPSHADER_TIMING_TIMING]
        Bitmap[c4d.BITMAPSHADER_TIMING_RANGEFROM]
        Bitmap[c4d.BITMAPSHADER_TIMING_RANGETO]
        Bitmap[c4d.BITMAPSHADER_TIMING_LOOPS]
        anyone?
