    Bake object
    4 Posts 0 Posters 859 Views
      On 25/09/2014 at 15:48, xxxxxxxx wrote:
      Is there a way to access / use the Bake Object function in the Timeline using Python?
      So, set variables in the Bake Object Dialog and simulate the OK button?
      c4d.CallCommand(465001219) # Bake Objects...
          tool=doc.GetAction()
          tool=c4d.plugins.FindPlugin(tool, c4d.PLUGINTYPE_TOOL)
      will open the dialog, but how proceed?
      Also the tool returned is not Bake Object...
      -Pim
        On 28/09/2014 at 12:30, xxxxxxxx wrote:
        Hi Pim,
        doc.GetAction() is the actual tool like e.g.liveselection.
        The dialog initializes the next tool, in this case the bake tool, but no action jet.
        As we discussed, here a small version of the bake tool to begin with.
        cheers
        Martin
        from c4d import gui,utils
        ##### monkeytack bake script #####
        def SetCTracks(self,pos,rot,scale,pla,animP) :
          trpX = None
          trpY = None
          trpZ = None
          trrX = None
          trrY = None
          trrZ = None
          trsX = None
          trsY = None
          trsZ = None
          trPLA = None
          trs = op.GetCTracks()
          if trs != None:
              for tr in trs:
                  if tr.GetDescriptionID()[0].id == c4d.ID_BASEOBJECT_POSITION:
                      if tr.GetDescriptionID()[1].id == c4d.VECTOR_X:
                          trpX = tr
                      if tr.GetDescriptionID()[1].id == c4d.VECTOR_Y:
                          trpY = tr
                      if tr.GetDescriptionID()[1].id == c4d.VECTOR_Z:
                          trpZ = tr
                  if tr.GetDescriptionID()[0].id == c4d.ID_BASEOBJECT_ROTATION:
                          trrX = tr
                          trrY = tr
                          trrZ = tr
                  if tr.GetDescriptionID()[0].id == c4d.ID_BASEOBJECT_SCALE:
                          trsX = tr
                          trsY = tr
                          trsZ = tr
                  if tr.GetDescriptionID()[0].id == c4d.CTpla:
                      trPLA = tr
          if animP == False:
              if pos == True and trpX == None:
                  trpX = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trpX)
              if pos == True and trpY == None:
                  trpY = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trpY)
              if pos == True and trpZ == None:
                  trpZ = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Z, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trpZ)
              if rot == True and trrX == None:
                  trrX = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_ROTATION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trrX)
              if rot == True and trrY == None:
                  trrY = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_ROTATION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trrY)
              if rot == True and trrZ == None:
                  trrZ = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_ROTATION, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Z, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trrZ)
              if scale == True and trsX == None:
                  trsX = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_SCALE, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trsX)
              if scale == True and trsY == None:
                  trsY = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_SCALE, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trsY)
              if scale == True and trsZ == None:
                  trsZ = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_SCALE, c4d.DTYPE_VECTOR, 0, ), c4d.DescLevel(c4d.VECTOR_Z, c4d.DTYPE_REAL, 0)))
                  self.InsertTrackSorted(trsZ)
          if pla == True and trPLA == None:
              trPLA = c4d.CTrack(self, c4d.DescID(c4d.DescLevel(c4d.CTpla, c4d.CTpla, 0)))
              self.InsertTrackSorted(trPLA)
              trs.append(trPLA)
          return trs
        def SetCurrentFr(FR, doc) :
          doc.SetTime(c4d.BaseTime(float(FR)/doc.GetFps()))
          doc.ExecutePasses(None, True, True, True, 0);
          c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
        def BakeObject(obj,doc,fFR,lFR,trs) :
          time = doc.GetTime()
          fps = doc.GetFps()
          #SendModelingCommand container for PLA
          settings = c4d.BaseContainer()
          settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE, True)
          settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, True)
          settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE,False)
          for FR in range(fFR,(lFR+1)) :
              c4d.StatusSetBar(100*(FR-fFR)/(lFR-fFR))
              CurrTime = c4d.BaseTime(FR,fps)
              #bake
              for tr in trs:
                  curve=tr.GetCurve()
                  val = curve.GetValue(CurrTime, fps)
                      newobjList = utils.SendModelingCommand(
                                  command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
                                  list= [obj.GetClone()],
                                  mode=c4d.MODELINGCOMMANDMODE_ALL,
                                  bc = settings,
                                  doc = doc)
                      newObj = newobjList[-1]
                      keyPLA = curve.AddKey(CurrTime)['key']
                      tr.FillKey(doc,newObj,keyPLA)
                      key = curve.AddKey(CurrTime)['key']
                      key.SetValue(curve, val)
              #update timeline
          print "object baked"
          #reset timeline
          doc.SetTime(time)
          c4d.EventAdd(c4d.EVENT_ANIMATE)
          c4d.StatusClear()
          if op==None:return
          #params
          fFR = 0        #firstframe
          lFR = 20      #lastframe
          allP = True
          if allP == True:
              p = True   #position
              r = True   #rotation
              s = True   #scale
              PLA = True #Pointlevel
          #else set some values
          animP = True  #only animated parameters
          trs = SetCTracks(op,p,r,s,PLA,animP)
          BakeObject(op,doc,fFR,lFR,trs)
          On 29/09/2014 at 00:45, xxxxxxxx wrote:
          Great, thank you.
          -Pim
            On 29/09/2014 at 06:50, xxxxxxxx wrote:
            you´re welcome.
            I guess the baking tool is´nt even a normal tool.
            I can´t find something about it in the docs.
            Anyway there is a lot to do to make it a full version.
            Baking expressions , clean up the tracks and make a copy.
            good luck
            Martin
