    BaseTag properties in attribute manager [CLOSED]
    3 Posts 0 Posters 235 Views
      On 25/09/2014 at 07:34, xxxxxxxx wrote:
      Cinema 4D Version:   13.061
      I like to see the BaseTag properties if I select only the object, which is assigned a tag. (e.g. the "Align to path" tag).
      I don't find a flag/setting for this behaviour.
      regards
        On 10/10/2014 at 05:07, xxxxxxxx wrote:
        Perhaps I misunderstand your request. You want to change the standard behavior of C4D, when the user is clicking onto an object in AM? I'm not sure this is at all desirable. The user should be able to rely on certain behavior and is expecting certain behavior. Now, how would he or she get back to the object properties, if the behavior was changed as you request? And who would decide, which tag to show in such case?
        The user can always add multiple AMs to his interface. These can then be locked to show the properties of a certain tag. This may further be improved using the filters built into the AM.
        On the other hand, I may have misunderstood your request completely.
          On 21/10/2014 at 05:43, xxxxxxxx wrote:
          Marky71, I'm wondering, if you were able to find a solution?
