    Scaling 2d planes to their texture..
    15 Posts 0 Posters 1.7k Views
      On 25/09/2014 at 01:21, xxxxxxxx wrote:
      Just saw you edit fella.
        On 25/09/2014 at 07:51, xxxxxxxx wrote:
        at the end!
        There are several places where your bitmap can be fund, according to the state of your document (saved or not)or your choice while loading the picture(make a copy or not).
        This script should work in any case.
        Let me know if not.
        cheers
        Martin
        import c4d,os
        from c4d import gui,bitmaps,storage
        from c4d.modules.render import  InitRenderStruct
          if op==None:return
          #not a plane primitive
          if op.GetType()!=5168:return
          if op.GetTag(c4d.Ttexture)== None:
              dialog=gui.MessageDialog("Please assign a material to the object",c4d.GEMB_OK)
              if dialog== 1:
              TexTag=op.GetTag(c4d.Ttexture)
          Mat= TexTag.GetMaterial()
          Shader=Mat[c4d.MATERIAL_COLOR_SHADER]
          if Shader.GetType() != c4d.Xbitmap:
              dialog=gui.MessageDialog("Please insert a picture",c4d.GEMB_OK)
              if dialog== 1:
          bitmapPath = Shader[c4d.BITMAPSHADER_FILENAME]
          #if bitmapPath is´nt absolute
          if not os.path.dirname(bitmapPath) :
              #the document has´nt been saved already ->picture in user library
              if not doc.GetDocumentPath() :
                  abspath= c4d.storage.GeGetStartupWritePath()+"/"+"tex"+"/"+bitmapPath
              #the picture should be inside the asset´s texture folder
                  abspath= doc.GetDocumentPath()+"/"+"tex"+"/"+bitmapPath
              abspath = bitmapPath
          print abspath
          bmp = bitmaps.BaseBitmap()
          if bmp.InitWith(abspath)[0]== c4d.IMAGERESULT_OK:
              if bmp != None:
                  bmpsize     = bmp.GetSize()
                  op[c4d.PRIM_PLANE_WIDTH]=bmpsize[0]
                  op[c4d.PRIM_PLANE_HEIGHT]=bmpsize[1]
                  op.Message(c4d.MSG_UPDATE)
                  #render the Bitmap if you like
                  #bitmaps.ShowBitmap(bmp)
          On 25/09/2014 at 17:31, xxxxxxxx wrote:
          Thanks for sticking in here with me.
          No joy. Maybe i'm doing something wrong. I dropped this code in a python tag on a plane object with a texture attached. Should that have worked?!
          Am i doing something wrong?
            On 25/09/2014 at 17:46, xxxxxxxx wrote:
            Yes, if you use a Python tag, than op is the Python tag and not the assigned object.
            You have to use obj= op.GetObject() instead.
            Have fun!
            Martin
            like:
            import c4d,os
              obj= op.GetObject()
              print obj
              if obj==None:return
              if obj.GetType()!=5168:return
              if obj.GetTag(c4d.Ttexture)== None:
                  if dialog== 1:
                  TexTag=obj.GetTag(c4d.Ttexture)
              print Shader
                  if dialog== 1:
              print abspath
                  if bmp != None:
                      obj[c4d.PRIM_PLANE_WIDTH]=bmpsize[0]
                      obj[c4d.PRIM_PLANE_HEIGHT]=bmpsize[1]
                      obj.Message(c4d.MSG_UPDATE)
            p.s.
            Don´t use EventAdd() than;)
              On 28/09/2014 at 09:51, xxxxxxxx wrote:
              I can't get this working, i'm going to try again tonight!?
                On 28/09/2014 at 10:54, xxxxxxxx wrote:
                be sure to use a plane primitive!!
                At the beginning of the script we exclude any other objects even a converted plane.
                like
                because at the end of the script we want to assign the bitmap size to the primitiv values.
                If this doesn´t work, post a scene file.
                cheers
                Martin
                  On 28/09/2014 at 16:34, xxxxxxxx wrote:
                  I've tried a couple of ways of applying the code but i can't get it working!?
                  I have been using a plane and i have tired many ways of applying the texture, still no joy.
                  http://www.doghouseanimations.com/resizing test code 3.zip
                  thanks again for your help..
                    On 28/09/2014 at 16:39, xxxxxxxx wrote:
                    sorry here is the hyperlink..
                      On 28/09/2014 at 17:35, xxxxxxxx wrote:
                      ok,
                      you did not use a regular project structure.
                      The Bitmap is only inside the project folder, but not in a separate "tex" folder like cinema4d usually set it up by default.
                      just create a new folder inside your project folder, name it tex, drag the picture into it and open the scene. works fine!
                      or
                      open the scene and safe it again including the asset. works fine!
                      or
                      There is a Texture Manager inside cinema4d which shows you every path of every texture in your scene
                      Adapt the script to your special needs, if you like
                      Please try to understand those lines by searching the sdk.:
                      and especially
                      I implemented a print statement for the abspath already, that you can read it in the console window.
                      cheers
                      Martin
                        On 28/09/2014 at 17:56, xxxxxxxx wrote:
                        That rocks, you are truly a superstar. I can't believe i missed that!
                        If your ever in Amsterdam there is a beer with your name on it..
                          On 29/09/2014 at 06:53, xxxxxxxx wrote:
                          you´re welcome.
                          I still just stumble through the code.
                          But I´ll take you up on the beer.
                          cheers
                          Martin
