    Howto create a dialog list tree?
    2 Posts 0 Posters 223 Views
      On 21/09/2014 at 06:53, xxxxxxxx wrote:
      Hello mates.
      Im want to create a dialog that is something like the object manager " a list dialog".
      i tried to look in the doc but could not find anything about creating a list dialog.
      there was a short example using popup. but thats not what i want and it was the wrong type.
      I basically need to have a dialog list where each item in the clist is clickeble "make highlighted".
      A short example would be great
      Thanks.
        On 25/09/2014 at 06:34, xxxxxxxx wrote:
        There is a class called TreeViewCustomGui which is implemented in Python but curretly not officially supported neither documented. But in general it works almost the same like it does in C++. Check out the documentation there. If used, test it properly before you deliver your plugin to customers!
