Mesh Defofmer Cages
On 17/09/2014 at 10:06, xxxxxxxx wrote:
I seem to be stuck on adding a cage to the mesh deformer.
I am using:
MeshDeformer[c4d.ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE] = CageMeshThis does not work. Is there a special way to add objects to a InExcludeData field? InsertObject() does not work either. but will return True...
On 17/09/2014 at 12:46, xxxxxxxx wrote:
import c4d def main() : mDeformer = doc.SearchObject("Mesh") cages = mDeformer[c4d.ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE] #The object you want to put into the "Cages" object list targetobj = doc.SearchObject("Cube") cages.InsertObject(targetobj,0) #After inserting the object we have to update the deformer to see them mDeformer[c4d.ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE] = cages c4d.EventAdd() if __name__=='__main__': main()-ScottA
On 18/09/2014 at 12:04, xxxxxxxx wrote:
Thanks ScottA!
