    GetInputEvent - Enter Key
    2 Posts 0 Posters 362 Views
      On 12/09/2014 at 17:21, xxxxxxxx wrote:
      I have a script / command plugin. On the main dialog is a text edit field, and a save button. How would I capture the input event of the enter key while in the dialog and have that run commands?
      Joe
        On 16/09/2014 at 03:17, xxxxxxxx wrote:
        It seems there is no special Event triggered when "Enter" was pressed. But you can check if "Enter" is pressed:
          def Message(self, msg, result) :
              bc = c4d.BaseContainer()
              ok = c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_ENTER, bc)
              if ok:
                  if bc[c4d.BFM_INPUT_VALUE] == 1:
                      print ("Enter is pressed!")
              return super(MyDialog, self).Message(msg,result)
        GetInputState [URL-REMOVED]let's you check any keyboard or mouse property. The "Enter" key is defined via c4d.KEY_ENTER[URL-REMOVED]. If the BFM_INPUT_VALUE[URL-REMOVED] is 1 the key is pressed.
