    Can't compile source code with string [SOLVED]
    SDK Help
    0
    10
    738
    • H
      On 05/09/2014 at 14:09, xxxxxxxx wrote:
      Cinema 4D Version:   14
      I have, in my code, variables of type String and variables of type string.
      I'm using some std:: stuff so I must use string instead of String.
      It compiles and works fine on my Mac.
      But while trying to compile it in Windows, I get lots of errors and the compilation fails.
      Is there anything that can be done?
      • H
        On 05/09/2014 at 16:49, xxxxxxxx wrote:
        Why does it compile without a single complain in Xcode and, in Visual Studio I get dozens of errors?!?
        • H
          On 05/09/2014 at 18:39, xxxxxxxx wrote:
          Are you making string explicit to the std library by using std::string for references?
          • H
            On 05/09/2014 at 18:46, xxxxxxxx wrote:
            I don't know what you mean.
            Can you give me an example?
            • H
              On 05/09/2014 at 18:52, xxxxxxxx wrote:
              std is a namespace.  You can declare the namespace for referencing objects in that space explicitly (std::space) or implicitly (using namespace std) somewhere at the top of the file.  Which to use will depend on if there are possible clashes.  Let's say you have a string type in std and another in another namespace included in your code.  If they are not explicitly declared, there is a chance that the compiler doesn't understand which one to use.  If you are just using 'string', you must add 'using namespace std'.
              • H
                On 06/09/2014 at 14:54, xxxxxxxx wrote:
                Thank you so much, Robert.
                What was happening was the I had these two lines:
                template <typename T> string tostr(const T& t) { ostringstream os; os<<t; return os.str(); }
                using namespace std;
                and I simply had to switch them, like this:
                The correct way is the second, of course. But it is weird that Xcode doesn't complain and makes it work, somehow.
                • H
                  On 06/09/2014 at 15:59, xxxxxxxx wrote:
                  Technically, you can declare 'using namespace' anywhere in the global scope of the source code.  You can do this with '#include" for headers as well.  It is generally safer to do these first nonetheless.  And you want to declare the namespace after any header that defines it (!).
                  • H
                    On 07/09/2014 at 09:29, xxxxxxxx wrote:
                    All what Kuroyume wrote. However, I would encourage you to not use "using namespace x" but instead use x::function. This avoids any library conflicts.
                    • H
                      On 07/09/2014 at 12:28, xxxxxxxx wrote:
                      Agreed! 🙂
                      • H
                        On 07/09/2014 at 12:56, xxxxxxxx wrote:
                        Thank you all. I will take that into account in the future.
                        In the meanwhile, I could make it all work now.
