    Render: frame addition and subtraction
    3 Posts 0 Posters 279 Views
      On 02/09/2014 at 08:15, xxxxxxxx wrote:
      Is it possible to add and subtract frames from a running render?
      For example: Rendering from 1-200 but would like to add frames 201-210 rather than adding it to the render queue.
      -Shawn
        On 02/09/2014 at 13:11, xxxxxxxx wrote:
        do you want do change a currently running render task? I don't think that's possible. But if you want  to render certain frames without using the default options you may use RenderDocument[URL-REMOVED].
          On 02/09/2014 at 15:00, xxxxxxxx wrote:
          Thanks for replying S_Bach,
          Correct I am trying to access and change the end frames of the currently running render. The main goal is to evenly distribute frames among the render farm using a custom "Net Render."
          I use a combination of RenderDocument and the send to picture viewer command, depending on the users preference.
