    detect a material has changed
    5 Posts 0 Posters 680 Views
      On 25/08/2014 at 12:51, xxxxxxxx wrote:
      Hi there,
      how can I detect that the user has changed a property of a shader which is used in a material? For example in the color channel.
      Thanks in advance
      Martin
        On 25/08/2014 at 15:23, xxxxxxxx wrote:
        Hi Monkeytack,
        I don't think there's a built-in method for detecting that specific change. In similar situations (detecting changes in Layer Selection, etc) - I've cached a copy of the object I'm monitoring and then checked it against the live copy every time there's a c4d.EVMSG_CHANGE message.
        -Donovan
          On 28/08/2014 at 04:27, xxxxxxxx wrote:
          thanks for the reply!
          do you have an example script?
           I was not able to implement your description?
          I have a tag plugin and I want to notify changes of the material which is, as the tag plugin, assigned to an object.
          How can I notify an EventMessage in my tag plugin and do the cache?
          Martin
            On 28/08/2014 at 13:07, xxxxxxxx wrote:
            a tag's Execute[URL-REMOVED] function is called pretty much every time something happens in the scene. So you could check there if the material's dirty state[URL-REMOVED] changed:
            class ExamplePythonTag(plugins.TagData) :
              materialDirtyStatus = 0
              def Init(self, node) :
                  # init your plugin here
              def Execute(self, tag, doc, op, bt, priority, flags) :
                  # search for texture tag
                  textureTag = op.GetTag(c4d.Ttexture)
                  if textureTag != None:
                      # get material
                      material = textureTag.GetMaterial()
                      if material != None:
                          # get dirty state
                          dirty = material.GetDirty(c4d.DIRTY_DATA)
                          # compare
                          if dirty != self.materialDirtyStatus:
                              print("material changed...")
                              self.materialDirtyStatus = dirty
                  return c4d.EXECUTIONRESULT_OK
              On 02/09/2014 at 02:47, xxxxxxxx wrote:
              Hello Sebastian,
              thank you for the reply!
              It works !
              best wishes
              Martin
