    Nested Cloners [SOLVED]
    26 Posts 0 Posters 13.8k Views
      On 25/08/2014 at 04:27, xxxxxxxx wrote:
      Cinema 4D Version:   13+
      does anybody know if it's possible to retrieve modata from a nested cloner (i.e. the cloner is a child of another cloner)?
      MSG_GET_MODATA works with the parent cloner but for the child cloner I don't even get a modata tag, which is the actual problem. I don't even get to the point of retrieval for that child cloner.
      Is this a bug or how is it supposed to work? Anybody tried that already?
        On 25/08/2014 at 05:42, xxxxxxxx wrote:
        I also checked if there are several modata tags on the parent cloner but there aren't.
        Also there is only one valid modata for index = 0. Other indices are uninitialised.
        Right now I cannot think of anything else... 😕
          On 25/08/2014 at 06:13, xxxxxxxx wrote:
          I found only this thread with the forum search for a related posting:
          https://developers.maxon.net/forum/topic/6927/7783_cloner--tag-with-excprioritygenerator&KW=cloner
          It's not exactly the same issue but the presented issue occurs with nested cloners as well (though it might be a priority issue)...so still no real hint if it is possible at all to retrieve modata for a nested cloner.
          This is really needed. 😞
            On 14/09/2015 at 10:43, xxxxxxxx wrote:
            I am coming back to this one year later becaue it's still not resolved. I am still looking for a way to read out nested cloners.
              On 15/09/2015 at 01:37, xxxxxxxx wrote:
              what exactly is your situation, are you trying to write an Effector or some other kind of plugin? If you could share some code showing what you are doing it would help us to understand the issue.
                On 15/09/2015 at 02:29, xxxxxxxx wrote:
                Hi Sebastian,
                thanks. I am in a Scene Hook::Execute() and I simply get the cloner (in that case nested cloners parent), the according motag and then use the message system to retrieve the modata accordingly. Something like this:
                    static inline bool get_cloner_modata(BaseObject* maincloner, GetMoDataMessage& msg_data, int moindex = 0)
                    		/* Find the MoData tag. */
                    		BaseTag* tag = maincloner->GetTag(ID_MOTAGDATA); if (!tag) return false;
                    //if the passed moindex is not 0 I would loop through available motags via tag->GetNext() but there is only 1 motag on the parent cloner
                    		/* Retrieve the MoData. */
                    		if (!tag->Message(MSG_GET_MODATA, &msg_data)) { return false; }
                    		if (!msg_data.modata) {
                    			GePrint("MSG_GET_MODATA did not return a MoData pointer.");
                    			return false;
                    		return true;
                Once I have the modata I browse the cloner's children accordingly with GetDown()/GetNext() (This works all fine. I get the matrix, offset etc. arrays from the modata accordingly. modata->GetCount() returns correctly the amount of clones that cloner produces).
                If one of the children is a cloner, I recurse with the same code.
                Pseudocode:
                    void get_mo_clones(BaseObject* root_cloner, BaseObject* cloner)
                    GetMoDataMessage msg;
                    if(!get_cloner_modata(cloner,msg)) return; //returns here for child cloners because no motag is found
                    clone_source_i = cloner->GetDown()
                    browse_cloner_children(cs){
                      //I cache them here for later use
                      cs = cs->GetNext();
                    MoData* md = msg.modata;
                    for_each_clone(child, md->GetCount()){
                       if(childtype == MOGRAPH_CLONER_ID)
                          get_mo_clones(root_cloner, child)
                       else{
                           //Do stuff...e.g. md->GetMatrixArray(MODATA_MATRIX)[i] etc.
                but on that cloner child cloner of course and that's what is not working as I explained in the above posts. There is no motag on that child cloner. Also there is only one modata available in the parent cloner and only a single motag (so no multiple data for child clones).
                All caches etc should be built when my SceneHook is evaluated, so the data should be there I guess. The question is where to get the motag/modata for possible nested child cloners. Any idea?
                  On 15/09/2015 at 03:46, xxxxxxxx wrote:
                  did you check activeobject plugin?
                    On 15/09/2015 at 03:50, xxxxxxxx wrote:
                    activeobject plugin? What do you mean by that Mohamed? All pointers are verified yes, if you mean that.
                      On 15/09/2015 at 06:01, xxxxxxxx wrote:
                      no, not meaning that Samir, there is a plugin example in the SDK, under GUI plugins, ActiveObject.cpp
                        On 15/09/2015 at 06:10, xxxxxxxx wrote:
                        Ok. Yes, I know the gui example, but how is it supposed to help me with this issue? Not sure I understand. Can you elaborate?
                        Except for the effector examples there's nothing MoGraph related in the sdk examples.
                          On 15/09/2015 at 06:13, xxxxxxxx wrote:
                          just create your nested clones in the object manager, then open the plugin, check how the hierarchy looks, it should do exactly what you want.
                            On 15/09/2015 at 06:20, xxxxxxxx wrote:
                            No, it does nothing what I want (at least I don't see anything helpful in my situation but I could be blind).
                            Please be more exact or post some code that shows how to retrieve the Modata/motag from a nested cloner with valid transformation matrix informations, so I know what you mean.
                            Imo the activeobject example does nothing but showing the hierarchy in a treeview. All the classes there are meant to let the treeview element handle a hierarchy. How is it supposed to help me with nested cloners and modata retrieval?
                            The hierarchy is known and I don't need direct access to the clones geometry (that is retrieved with GetDeformedCache for example) but to the internal procedural clone data of the cloner which the modata provides.
                              On 15/09/2015 at 07:04, xxxxxxxx wrote:
                              you will need to get that cached object, access its container.
                                On 15/09/2015 at 09:08, xxxxxxxx wrote:
                                I could no reproduce any problems. You told that you browse the cloner's children with GetDown(). But these children (objects you see in the Object Manager) are no clones. The only clones exist in the cache of the cloner. When you access the cache of the cloner and access the cloned cloners there, they will have a MoGraph tag.
                                  On 15/09/2015 at 10:36, xxxxxxxx wrote:
                                  ok, I am absof**kinglutely stupid and you guys are totally darn right! Really, this is so basic, I feel ashamed. I haven't had the slightest thought about virtuality of the result that it never even crossed my mind to look that way (even though I was talking about the procedural data. Someone please hit me).
                                  My apologies to Mohamed as well. You pointed in the right direction but as I mentioned I was totally ignorant about thinking this out further. Apparently I don't need sleep, I need vacation. 😵
                                  Anyway, will try this first thing in the morning but it seems that was my missing piece. Hate myself right now.
                                  Thanks guys (also for being patient sometimes with me !Ermm[URL-REMOVED])!!
                                    On 15/09/2015 at 11:22, xxxxxxxx wrote:
                                    this is common Samir, I always do this "test a lot , get a whole picture, and miss a small detail".
                                    glad that it helped
                                      On 23/10/2015 at 04:43, xxxxxxxx wrote:
                                      sorry guys, gotta steal your time once again as I now know why I used the "normal" clones in the first place (sorry, didn't recall before but only today when I indeed tried this). I am in a SceneHook Execute() function and GetCache as well as GetDeformCache always return a nullptr.
                                      SendModellingCommand only seems to return the final polygonal hierarchy. So is there a way to access the virtual cache from here anyhow?
                                      Maybe I need to clone the doc somehow, let the cache be rebuilt (which would probably impose a performance penalty if dynamics need to be recalculated for the frame of retrieval?) and read the cache then? I'd rather not because this would also include my own dynamic calculations to be redone which is really no option (it could be hours of simulation time for previous frames...worst case scenario).
                                      Maybe there is a way to rebuilt the caches?
                                      Thanks again!
                                        On 26/10/2015 at 01:53, xxxxxxxx wrote:
                                        what exactly are you doing in you SceneHook and when? In AddToExecution() you can define when in the execution pipeline your scene hook is called.
                                          On 26/10/2015 at 05:49, xxxxxxxx wrote:
                                          what exactly do you mean by "what exactly are you doing"?
                                          I am grabbing an object from the OM (my own object plugin) and reading out an object (in this case the Cloner but it doesn't matter what object, it's always nullptr) from a link field of it. Then trying to get the cache.
                                          obj = my_op->GetDataInstance()->GetObjectLink(ID);
                                          obj->GetCache()
                                          execution pipeline priority is EXECUTIONPRIORITY_DYNAMICS (which I want to be in btw.)
                                            On 26/10/2015 at 06:06, xxxxxxxx wrote:
                                            I assume caches are not yet built (but will be only in EXECUTIONPRIORITY_GENERATORS) so I guess I need pre-built caches?
                                            Can I use the Hierarchy class for this purpose?
