    creating a custom node system
    16 Posts 0 Posters 3.3k Views
      On 16/08/2014 at 13:07, xxxxxxxx wrote:
      seems like a nightmare xD, I guess I will do it in Qt and embed it somehow
        On 16/08/2014 at 13:34, xxxxxxxx wrote:
        Qt?
          On 16/08/2014 at 13:50, xxxxxxxx wrote:
          http://qt-project.org/
            On 16/08/2014 at 14:43, xxxxxxxx wrote:
            Ah!  First thing that i thought was QuickTime, was confused 😄
            I have to be honest i`m still trying to get my head around how the custom GUI etc stuff works in C4D, without many solid examples ( at least that i can find ) it is really really difficult to put the different parts of the puzzle together..
            But in saying that - for me its been like that with everything in the api, its like a maze.  Once you know how it works you realise it is actually really simple.  Give people more and better example code and practical reference material Maxon guys ffs!!!  I cant stress that enough!!  I could have saved literally weeks if id had the knowledge i have now, laid out in an organised and accessible way, to learn from.
            Anyway, i completely digress.  The point i was going to make was, maybe its worthwhile learning the GeUserArea stuff.  If you use an alternative framework such as Qt for UI, youre still going to have to implement all the object classes, data classes, etc etc..  So why not 🙂
              On 16/08/2014 at 17:52, xxxxxxxx wrote:
              And, as a warning, interfacing OpenGL Qt with Cinema 4D is not a done deal.  I have had no success and it appears that others have had similar issues getting them to play well together.
                On 18/08/2014 at 07:47, xxxxxxxx wrote:
                Howdy,
                If by chance you can get in touch with David Farmer (darf), he may be able to offer you some advice, as he had started a plugin for R7 called Blunt Trauma that was a node based expression plugin.
                Adios,
                Cactus Dan
                  On 18/08/2014 at 09:31, xxxxxxxx wrote:
                  @Robert I think I know the way to put Qt UI inside Cinema4D Tongue , testing it today
                  @Cactus Dan does he have any website or email so I contact him?
                    On 18/08/2014 at 09:47, xxxxxxxx wrote:
                    Howdy,
                    His user name here on plugin cafe is "darf". You might be able to send him a PM.
                    Adios,
                    Cactus Dan
                      On 18/08/2014 at 13:54, xxxxxxxx wrote:
                      creating your own node system is an ambitious task. And as stated before you may use a GeUserArea within a GeDialog.
                      So the first thing to do is to create you own dialog. You just need a dialog class based on GeDialog[URL-REMOVED]. An example is the ActiveObjectDialog in the SDK.
                      class ExampleDialog : public GeDialog
                        ExampleDialog()
                        virtual Bool CreateLayout()
                            SetTitle("My Node System");
                            return true;
                      The layout of the dialog is defined in the CreateLayout function. Elements are not placed by absolute coordinates but are arranged in groups like in Cinemas *.res files. You can add Cinema's default widgets, menues and your own interactive widgets. Such a widget must be based on GeUserArea[URL-REMOVED]. An example is the SDKGradientArea in the SDK.
                      class ExampleUserArea : public GeUserArea
                        virtual void DrawMsg(Int32 x1, Int32 y1, Int32 x2, Int32 y2, const BaseContainer& msg)
                            // we will draw the widget here
                        virtual Bool InputEvent(const BaseContainer& msg)
                            // we will handle user input here
                            return true;
                      The widget is drawn in DrawMsg :
                            OffScreenOn();
                            // draw background
                            DrawSetPen(Vector(0.8, 0.8, 0.8));
                            DrawRectangle(0, 0, 400, 400);
                            // draw a simple rectangle
                            DrawSetPen(Vector(0.4, 0.4, 0.9));
                            DrawRectangle(100, 100, 200, 200);
                      You want to be able to interact with your nodes by clicking on them. To catch user interaction events use the InputEvent function:
                            GeData data;
                            // check if mouse event
                            msg.GetParameter(DescLevel(BFM_INPUT_DEVICE), data);
                            if (data.GetInt32() == BFM_INPUT_MOUSE)
                                // check if left mouse button
                                msg.GetParameter(DescLevel(BFM_INPUT_CHANNEL), data);
                                if (data.GetInt32() == BFM_INPUT_MOUSELEFT)
                                    // now get the coordinates
                                    msg.GetParameter(DescLevel(BFM_INPUT_X), data);
                                    const Int32 xCoordiante = data.GetInt32();
                                    msg.GetParameter(DescLevel(BFM_INPUT_Y), data);
                                    const Int32 yCoordiante = data.GetInt32();
                                    GePrint("UserArea hit at " + String::IntToString(xCoordiante) + " : " + String::IntToString(yCoordiante));
                            return true;
                      Finally you need to use your UserArea within your dialog:
                            C4DGadget * userAreaGadget = this->AddUserArea(1000, BFH_LEFT, 400, 300);
                            this->AttachUserArea(_exampleUserArea, userAreaGadget);
                            return true;
                      You simply create a new C4DGadget of the type UserArea and then attach an instance of your UserArea (_exampleUserArea) to this gadget.
                      Based on the user interaction you can update your node system; in DrawMsg you can draw you node system. Another thing is when you want to solve your node system; when should it be executed? This can happen when a new frame is processed; you may take a look at this thread.
                      With these elements you are able to build your own fully functional GUI. But still, building your own node system is a big undertaking that needs good planning.
                        On 18/08/2014 at 13:58, xxxxxxxx wrote:
                        Holy hell good post ^
                          On 18/08/2014 at 15:40, xxxxxxxx wrote:
                          @Sebastian really thanks a lot for this info, I really like it, will do my best to replace xpresso soon 🙂
