    Inserting Description Elements via Code..
    6 Posts 0 Posters 526 Views
      On 15/08/2014 at 04:40, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      Im trying to figure out how to insert a Description element to my objectdata plugin via code.  I already have various plugin options showing up via the res files etc and so am trying to basically grab the nodedatas Description container and insert a new Real parameter into it ( in such a way that it will show up in the attributes along with everything else when the plugin is launched ).
      At the moment i am using Description->SetParameter() to achieve this by inserting a new BaseContainer that has been given test values for DESC_NAME, DESC_SHORT_NAME and DESC_UNIT but it isn`t showing up in the attributes manager.
      I think it may be something to do with creating proper DESC_IDs or something.  Either that or i am going about this in completely the wrong way!  Which is possible as its a bit like wandering around in the dark trying to figure this stuff out without proper examples..
      Heres the code i have which although the if statement is returning it is done, it isnt displaying the parameters as mentioned:
      Bool MyPlugin::Init(GeListNode *node)
      	AutoAlloc<Description> desc;
      	node->GetDescription(desc, DESCFLAGS_DESC_0);
      	BaseContainer *descBC = desc->GetParameterI(MYPLUGIN_OBJECTWIDTH, NULL); // This returns an existing parameter successfully
      	BaseContainer newBC = BaseContainer();
      	newBC.SetString(DESC_NAME, "My Description Param");
      	newBC.SetString(DESC_SHORT_NAME, "My Description Param");
      	newBC.SetLong(DESC_UNIT, DESC_UNIT_REAL);
      	if (desc->SetParameter(MYPLUGIN_NEWPARAMETER, newBC, DESCID_ROOT))
      		GePrint("it is done");
      	else
      		GePrint("it is not done");
        On 15/08/2014 at 05:45, xxxxxxxx wrote:
        Howdy,
        You need to do that in the NodeData::GetDDescription() function. Do a search for GetDDescription here on plugin cafe and you'll find plenty of examples. 😉
        Adios,
        Cactus Dan
          On 15/08/2014 at 06:09, xxxxxxxx wrote:
          Also, it is necessary that you include the Datatype ID in the Description ID you use for SetParameter().
            On 15/08/2014 at 07:38, xxxxxxxx wrote:
            Very much appreciated guys, thank you.
            RE the Datatype ID Niklas - do you mean i`d create a DescID with my parameter ID, then insert the Datatype ID into that - using say DescID->PushId() ?
            Maybe like this?
            DescID MYPLUGIN_NEWPARAMETER = DescID(MYPLUGIN_NEWPARAMETER);
            MYPLUGIN_NEWPARAMETER.PushId(DESC_UNIT_REAL); desc->SetParameter(MYPLUGIN_NEWPARAMETER, newBC, DESCID_ROOT);
            I`m probably confusing things for myself 😕
              On 15/08/2014 at 07:55, xxxxxxxx wrote:
              Nope, like this
              DescID descId(DescLevel(MYPLUGIN_NEWPARAMETER, DA_REAL, 0));
              DESC_UNIT_REAL is not a datatype ID. If you create a Floating-point parameter, use DA_REAL,
              for an Integer parameter DA_LONG, for SplineData CUSTOMDATATYPE_SPLINE, etc.
              Best,
              -NIKLAS
                On 15/08/2014 at 10:05, xxxxxxxx wrote:
                Okay - thanks for that, much appreciated.
