    Python_gradient gizmo won't maximize
    4 Posts 0 Posters 935 Views
      On 02/08/2014 at 19:00, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Language(s) :
      I can't open the gradient gizmo's options pallet when creating it with AddCustomGui() function.
      SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED) does not work.
      Example of the various things I've tried to maximize the gizmo:
      import c4d,os,sys
      from c4d import plugins, utils, bitmaps, gui, documents
      Plugin_ID = 1000010    #Testing id ONLY!!!!!!!
      MY_GRADIENT = 10001
      class MyDialog_Gui(gui.GeDialog) :
        myGradGizmo = None
        gradient = c4d.Gradient()
        def CreateLayout(self) :
            #Create the gradient gui here
            #We will change it's options in the InitValues() method
            gSettings = c4d.BaseContainer()
            #gSettings.SetBool(c4d.LAYOUTMODE_MAXIMIZED, True)  #<---Wrong!!!
            #gSettings.SetLong(c4d.LAYOUTMODE_MAXIMIZED, 2)     #<---Wrong!!!
            #gSettings.SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED)  #<---Wrong!!!
            self.myGradGizmo = self.AddCustomGui(MY_GRADIENT, c4d.CUSTOMGUI_GRADIENT, "", c4d.BFH_SCALEFIT|c4d.BFV_CENTER, 0, 0, gSettings)
        def InitValues(self) :
            #To change the gradient gui we have to first create a gradient object and fill it with data
            #Then we copy the settings to the CUSTOMGUI_GRADIENT we created in the CreateLayout() method
            self.gradient.InsertKnot(col = c4d.Vector(0.0, 0.0, 0.0), pos = 0.0,index = 0)
            self.gradient.InsertKnot(col = c4d.Vector(1.0, 1.0, 1.0), pos = 0.5,index = 1)
            self.gradient.InsertKnot(col = c4d.Vector(1.0, 1.0, 1.0), pos = 1.0,index = 2)
            self.gradient.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENT_INTERPOLATION_NONE)
            self.gradient.SetData(c4d.GRADIENT_MODE, c4d.GRADIENTMODE_COLOR)
            #self.gradient.SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED)      #<---Wrong!!!
            #self.myGradGizmo.SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED)   #<---Wrong!!!
            self.myGradGizmo.SetGradient(self.gradient)
        def Command(self, id, msg) :
        def CoreMessage(self, id, msg) :
      #   MyDialog_Main --- Where the plugin stuff happens--Don't edit this part
      class myDialog_Main(plugins.CommandData) :
        dialog = None
        def Execute(self, doc) :
            #Create the dialog
            if self.dialog is None:
                self.dialog = MyDialog_Gui()
            return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=Plugin_ID, xpos=-1, ypos=-1)
        def RestoreLayout(self, sec_ref) :
            #Manage the async dialog so it can be docked in the UI
            return self.dialog.Restore(pluginid=Plugin_ID, secret=sec_ref)
       path, fn = os.path.split(__file__)
       #bmp = bitmaps.BaseBitmap()
       #bmp.InitWith(os.path.join(path, "res/icons/", "None")) #Uses a folder called "icons" inside the "res" folder to hold the icon
       plugins.RegisterCommandPlugin(Plugin_ID, "LinkBox Example", 0, None, "", myDialog_Main())
        On 13/01/2015 at 04:57, xxxxxxxx wrote:
        I was also struggling with the gradient UI.
        It is now working, also thanks to this above example.
        Except, there are 6 knots in the gradient and not 3 as defined.
        When you drag a knot you can see another one beneath it.
        It seems every knot is inserted twice?
        What am I doing and the example above doing wrong?
        -Pim
          On 14/01/2015 at 03:47, xxxxxxxx wrote:
          SetLayoutMode() is not available in Python. But it is possible to set a value for CUSTOMGUI_LAYOUTMODE in the BaseContainer used with AddCustomGui() :
          bc = c4d.BaseContainer()
          bc.SetInt32(c4d.CUSTOMGUI_LAYOUTMODE,c4d.LAYOUTMODE_MAXIMIZED)
          gradient = self.AddCustomGui(id=4000, pluginid=c4d.CUSTOMGUI_GRADIENT, name="gradient", flags=c4d.BFH_LEFT, minw=400, minh=20, customdata = bc)
          The behavior that two knots are inserted instead of one is indeed a bug. A bug report was filed.
            On 14/01/2015 at 04:14, xxxxxxxx wrote:
            Thanks for the reply.
            It is good to know it is a bug.
            I spend about a day debugging/trying/testing before asking the question this forum.
