    Export a single object
    5 Posts 0 Posters 598 Views
      On 29/07/2014 at 05:29, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Platform:      Mac OSX  ;
      I would like to export a single object to disk, in .OBJ format.
      To export in .OBJ format I can use the SaveDocument command, I believe.
      But to save just one object, not the entire scene, must I create a temporary document and save that? Should I use the IsolateObjects command to do so?
        On 29/07/2014 at 07:13, xxxxxxxx wrote:
        Hello Rui,
        i did the same thing once and i did i just created a temp document and inserted the object into it, then exported the temp doc into the desired file-format.
        I have never used IsolateObjects yet, but it looks like it does the same thing, so it should work as well.
        greets,
          Daniel
          On 29/07/2014 at 07:44, xxxxxxxx wrote:
          Thank you very much, Daniel. I will try it out, as soon as I get back from vacation.
          Rui Batista
            On 29/07/2014 at 08:25, xxxxxxxx wrote:
            i just checked my code from back then and it looks like i actually *did* use the IsolateObjects function..
            here's an example of how it should work:
                static void exportSelected(BaseDocument* doc, Filename exportFileName){
                	if(!doc) return;
                	// get all selected objects
                	AtomArray* ar = AtomArray::Alloc();
                	doc->GetActiveObjects(*ar,TRUE);
                	if(ar->GetCount()<1) return;
                	// copy all objects in Array 'ar' to tmpDoc
                	BaseDocument* tmpDoc = IsolateObjects(doc,*ar);
                	// save doc to file
                	if(tmpDoc){
                		if(SaveDocument(tmpDoc,exportFileName,SAVEDOCUMENTFLAGS_0,FORMAT_OBJEXPORT)){
                			GePrint("exported selected objects to file "+exportFileName.GetFileString());
                		else GePrint("could not export selected objects to file "+exportFileName.GetFileString());
              On 29/07/2014 at 09:12, xxxxxxxx wrote:
              WOW! Great. Your code will be of great help.
              Thank you, Daniel.
