    ResEdit for Tags and other Menus in C4D [SOLVED]
    Scheduled Pinned Locked Moved ResEdit
    5 Posts 0 Posters 2.9k Views
      On 14/07/2014 at 15:15, xxxxxxxx wrote:
      ResEdit Version:   R8
      C4D Version: Cinema4d Studio R15
      ResEdit Version for R14 (old one, but works with R15)
      OS: Windows 7
      Language: C++
      Hi PluginCafe,
      I would like to write a Tag-Plugin like the "LookAtCamera" Tag from the samples. For my Diaglog plugin I use ResEdit to design my layout etc. and import this with a view lines of code in C++. I don't have to write all those different files, because ResEdit creates them for me:-)
      Now how would I use ResEdit to design menu structures for Tag-Plugins (inherited from TagData). Or let's say I want to write a material plugin, is it possible to use ResEdit for such plugins or is its purpose to work with dialogs/windows only?
      Are there other tools/plugins/editors available to design menus in Ciname4d?
      Thank you for now!
      Andreas
        On 15/07/2014 at 05:42, xxxxxxxx wrote:
        To write a tag you will have learn how to create descriptions by hand in a text editor. They're not difficult and in any case ResEdit can't be used for descriptions. TBH for dialog resources ResEdit produces a weird and difficult to change resource file anyway.
        Just IMO of course, but I haven't used ResEdit for a long time, and don't miss it.
          On 17/07/2014 at 13:38, xxxxxxxx wrote:
          Thank you spedler. I had the hope that I don't need to learn how to write all those resource files by hand 😉
          I found this tutorial:
          http://irisvfx.com/blog/tutorials/introduction-cinema-4d-sdk-part-2/
          It would be nice if Cinema4d would have such graphical illustrations in their documentation.
          I will start learning to write descriptions for tags etc. from the docu and by experimenting with the samples. Of course I am open for any links and hints for additional examples/tutorials etc. 🙂
            On 17/07/2014 at 16:53, xxxxxxxx wrote:
            You can use the .res files that ship with C4D to learn from. There's a lot of them.
            That's how I learned how to make them.
            C:\Program Files\MAXON\Your_C4D_version\resource\res\description
              On 22/07/2014 at 18:28, xxxxxxxx wrote:
              You are right, ResEdit is not needed. The .res files in the Cinema4d folder "...\resource\res\..." are a pretty cool place to look for examples.
              Just some links for others to get started with:
              Plugin Folder Structure[URL-REMOVED]
              Dialog Resource[URL-REMOVED]
              Description Resource[URL-REMOVED]
