    Performance
    Scheduled Pinned Locked Moved General Discussion
    4 Posts 0 Posters 1.5k Views
      On 22/11/2002 at 03:34, xxxxxxxx wrote:
      What gives better performance when executing (so which version is faster) :
          for(i=0;i>xx;i++)
             if(type==1) {[.....] some stuff to do}
             else if(type==2) ....
             [...] some more conditions
      or
          if(type==2)
               for(i=0;i>xx;i++)
              {do some stuff}
          else if(type==3)
               for(i=0;i>xx;i++)
              {do some other stuff}
          ?? What do you think.
        On 22/11/2002 at 07:38, xxxxxxxx wrote:
        Definately the second one is faster.
        With the first one you are testing 'type' xx times,
        but it will always give the same result.
        The second approach exploits this, and your loop has no conditionals in it because of this.
        Only use the first version if the test is dependent on the iteration number. I'd also recommend replacing the string of 'if else' statements with a single 'switch' e.g.:
        If type is dependent on i, use this:-
        for(int i=0;i<xx;i++){
        switch(type [ i ] ){
        case 1:
            // Do stuff
            break;
        case 2:
            // Do stuff
            break;
        case 3:
            // Do stuff
            break;
        default:
            // Handle unexpected cases here - i.e. error.
            break;
        If type is _not_ dependent on i, then use this:-
        switch(type){
        case 1:
            // Do stuff
        break;
        case 2:
            // Do stuff
        break;
        case 3:
            // Do stuff
        break;
        default:
            break;
        You should always add a 'default' handler in there. This doesn't slow your code down (assuming its compiled not interpreted, e.g. C++ rather than coffee), and is a very good habit to get into because you then get a warning when a case happens that you haven't explicitly allowed for.
        Another general rule, when nesting loops, make the loop that has the most iterations the inner one.
        i.e. use this:-
        for(i=0;i<10;i++) {
        for(j=0;j<100;j++) {
            // Do stuff based on i,j...
        instead of this:-
        for(i=0;i<10;i++) {
        P.S. I though the point of the '[' CODE ']' blocks was to
        stop the parser messing up code listings?
          switch is only a overview thing but while developement I don´t really care about that. Spaghetti code is my thing. 🙂
          thanks for the comment on the loop. I will then use the second one.
          I only use a default handler when it is possible that anything else could happen. But using a combo menu it is not possible any other case appears so I am saving time.
          thx
          Samir
            On 10/12/2002 at 13:37, xxxxxxxx wrote:
            As another time saver if you are in a situation where you are using switch/case blocks with a large number of cases, try a map with the case type as the key and function pointers for the values. It isn't worth it for a small number of cases, but it can be very nice for a large number. A side benefit is that you never again have the problem of forgetting to put in a break.
            John
