    BaseArray access problem [SOLVED]
    6 Posts 0 Posters 525 Views
      On 06/07/2014 at 22:19, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Language(s) :
      Hi
      I am creating a BaseArray:
      c4d_misc::BaseArray<Vector> MyVectorArray
      If I try to pass it to a function, the compiler throws an error:
      'c4d_misc::BaseArray<T>::BaseArray' : cannot access private member declared in class 'c4d_misc::BaseArray<T>'
      I can pass a GeDynamicArray to a function without problems, but I would like to use BaseArray for its speed.
      So basically, how do I pass a BaseArray to a function.
        On 08/07/2014 at 12:57, xxxxxxxx wrote:
        No hint on passing a BaseArray to a function?
        	c4d_misc::BaseArray<Vector> MyVectorArray;
        	MyVectorArray.Resize(10);
        	for (int i=0; i<10; i++) MyVectorArray[i] = Vector(0,i,0);
        	GePrint(RealToString(MyVectorArray[5].y));   			         //5  This works!!!
        	printVectorBaseArray(MyVectorArray);			            	//DOES NOT WORK....BaseArray is Inaccessible!!!
        void printVectorBaseArray(c4d_misc::BaseArray<Vector> inputVectorArray)
               GePrint(RealToString(inputVectorArray[5].y));
          On 08/07/2014 at 13:51, xxxxxxxx wrote:
          It protects you from passing the array by value, which is what you are doing. The function call
          would require to copy the whole array. Pass it as a pointer or reference (usually preferred).
          void printVectorBaseArray(c4d_misc::BaseArray<Vector> **&** inputVectorArray)
          -Niklas
            On 08/07/2014 at 15:18, xxxxxxxx wrote:
            It works. Thanks Niklas!
              On 09/07/2014 at 08:19, xxxxxxxx wrote:
              But please do not forget about  const  if the array do NOT need to be modified inside function.
              void printVectorBaseArray( **const** c4d_misc::BaseArray<Vector> **&** inputVectorArray)
                On 09/07/2014 at 11:18, xxxxxxxx wrote:
                That's a good tip, thanks Remo!
