    IsDirty and GetDirty
    2 Posts 0 Posters 224 Views
      On 04/07/2014 at 02:57, xxxxxxxx wrote:
      I like to check using a plugin or a script, whether the object has changed.
      IsDirty is not giving me any information, so I use GetDirty and check whether that value has changed.
      That is ok when in Model mode, but when in Polygon mode, the value returned by GetDirty is not changed when I move a polygon?
      DIRTY_MATRIX and the others are all returning the same value.
      How to check whether a polygon has moved, scaled or rotated?
      from c4d import gui
          obj = doc.SearchObject("Cube")
          print "--- IsDirty ---"
          print "Get DIRTY_MATRIX", obj.GetDirty(c4d.DIRTY_MATRIX)
          print "Get DIRTY_SELECT: ", obj.GetDirty(c4d.DIRTY_SELECT)
          print "Get DIRTY_CACHE: ", obj.GetDirty(c4d.DIRTY_CACHE)
          print "Get DIRTY_CHILDREN: ", obj.GetDirty(c4d.DIRTY_CHILDREN)
        On 04/07/2014 at 04:54, xxxxxxxx wrote:
        IsDirty() should be used for Generator plugins only.
        You know there is another one, DIRTYFLAGS_DATA, right? This one is changed
        when the polygons or points changed of an object.
        Best,
        -Niklas
