    Place an Objet with obj.SetMg(m)
    5 Posts 0 Posters 556 Views
      On 04/07/2014 at 00:35, xxxxxxxx wrote:
      I want to place an Object on a given global Koordinate.
      What i have is a Matrix with 16 Values like:
      "1,0,0,0,0,1,0,0,0,0,1,0,0,0,5,1.439"
      I read the documentation and found in the Topic "Matrix Fundamentals"
      that my matix is like this:
            1     0     0     0      1     0     0     0
          v0.x v1.x v2.x v3.x     0     1     0     0
      m = v0.y v1.y v2.y v3.y = 0     0     1     0
          v0.z v1.z v2.z V3.z     0     0     1   1.439
      Here my question:
      How can I convert my Data-Structure so, that i can write it in the command
      obj.SetMg(Matrix)
      here my aktual code
      coord = LINEDATA.split(",")
                          #print coord
                          #print ("Datenzeile enthält " + str(len (coord)) + " Datensätze")
                          MA1 = float(coord[0])
                          MA2 = float(coord[1])
                          MA3 = float(coord[2])
                          MA4 = float(coord[3])
                          MA5 = float(coord[4])
                          MA6 = float(coord[5])
                          MA7 = float(coord[6])
                          MA8 = float(coord[7])
                          MA9 = float(coord[8])
                          MA10 = float(coord[9])
                          MA11 = float(coord[10])
                          MA12 = float(coord[11])
                          MA13 = float(coord[12])
                          MA14 = float(coord[13])
                          MA15 = float(coord[14])
                          MA16 = float(coord[15])
                          Matrix = [[MA1,MA2,MA3,MA4],[MA5,MA6,MA7,MA8],[MA9,MA10,MA11,MA12],[MA13,MA14,MA15,MA16]]
                          print Matrix
                          #c4d.SetPoint(i,c4d.Vector(x,y,z))
                          obj = c4d.BaseObject(c4d.Onull)        # Create new cube
                          #obj.SetRelPos(c4d.Vector(20))           # Set position of cube
                          obj.SetMg(Matrix)
                          doc.InsertObject(obj)                   # Insert object in document
      Thanks a lot
        On 04/07/2014 at 03:12, xxxxxxxx wrote:
        Why don't you use the given function in that matrix chapter:
        You only need to define v0 - offset and v1,v2,v3 - scale and rotation.
        E.g. SetGlobalScale(obj, c4d.Vector(1.0, 1.0, 1.439))
        SetGlobalPosition(obj, pos) # Sets the global position of obj to pos
        SetGlobalRotation(obj, rot) # Sets the global rotation of obj to rot
        SetGlobalScale(obj, scale)  # Sets the global scale of obj to scale
          On 04/07/2014 at 05:31, xxxxxxxx wrote:
          it sounds so easy
          but:
          how do I define v_0 (i think this is the offset
          how do I define v_1
          how do I define v_2
          how do I define v_3
          how do I define pos
          how do I define rot
          how do I define scale
          I know it is in my linedata
          here an example: "1,0,0,0,0,1,0,0,0,0,1,0,0,0,5,1.439"
          But i dont know how to convert it.
          Sorry for sutch stupid questions
          Here is my actual code
          for line in DATA:
              LINEDATA = line.strip()                    #lese den Zeileninhalt ohne rechte Leerzeichen
              if (LINEDATA.find (SUCHSTRING_DATA) != -1) :
                  l = len(SUCHSTRING_DATA)
                  LINEDATA = LINEDATA[l:]
                  LINEDATA = LINEDATA[:-4]
                  print "Begin neuer Datensatz"
                  # Umwandlung in floating
                  for i in range(16) :
                      coord[i] = float(coord[i])
                      #print ("Coord", i , "= ",coord[i])
                      #print i
                      continue
                  print (coord)
                  # Definition der Vektoren
                  v_1 = c4d.Vector( coord[5] , coord[9] , coord[13] )
                  v_2 = c4d.Vector( coord[6] , coord[10] , coord[14] )
                  v_3 = c4d.Vector( coord[7] , coord[11] , coord[15] )
                  off = c4d.Vector(0,0,0)
                  print ( v_1 , v_2 , v_3, off)
                  print ()
                  print (v_1)
                  print (v_2)
                  print (v_3)
                  print (off)
                  mat = (v_1,v_2,v_3,off)
                  obj = c4d.BaseObject(c4d.Onull)        # Create new nullobject
                  obj.SetMg(mat)
            On 04/07/2014 at 07:01, xxxxxxxx wrote:
            Looks good.
            But make
            mat = c4d.Matrix(off, v_1, v_2, v_3)
            instead.
              On 04/07/2014 at 07:15, xxxxxxxx wrote:
              Jipiayay
              small change, big impact.
              it works.
              Thanks a lot
