    Using a BaseObject as Polygon
    6 Posts 0 Posters 1.5k Views
      On 21/11/2002 at 08:20, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      How can I use a BaseObject as a PolygonObject? I am casting it to a Polygonobject and change for example a point (in position). That works fine when the object is a Polygonobject in Cinema 4D (and I can see the point moving in C4D). But when it is still a BaseObject (PrimitiveObject ie Sphere) in Cinema 4D it doesn´t work.
      So how can I use it as if it was a Polygonobject? It sure is just a simple thing, but I can´t make it anyway. 🙂
        On 21/11/2002 at 10:03, xxxxxxxx wrote:
        You can't. But you can convert it to a PolygonObject with:
            BaseObject* GetDeformedObject(BaseObject* obj, BaseDocument* doc)
             if (!obj) return NULL;
             ModelingCommandData cd;
             cd.doc = doc;
             cd.op = obj;
             if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT,cd)) return NULL;
             return cd.result1;
          On 21/11/2002 at 11:01, xxxxxxxx wrote:
          Thanks that worked but it somehow gives me a really strange result. 😕 It seems the returned BaseObject is somehow corrupted. When using a normal polygonobject and using the new code with a primitive it looks completely different and weird.
          I will have a look in my code. Maybe it´s something in there but I couldn´t find anything yet.
          I´ll get back to you when I know more.
          Best
          Samir
            On 21/11/2002 at 11:45, xxxxxxxx wrote:
            Oh yeah, something is definetly wrong with the returned object. When I use my code my deformer deforms with no strenght a sphere to this result:
            But when I use my code with the function you gave me (that looks alright to me anyway) I get this result with no strenght:
            I couldn´t find a mistake in my code. Everything is still the same. Now I only ask for the object type:
                Bool VertexNormal::ModifyObject(PluginObject *mod, BaseDocument *doc, BaseObject *op, const Matrix &op_mg, const Matrix &mod_mg, Real lod, LONG flags, BaseThread *thread)
                PolygonObject* obj;
                if(!op->IsInstanceof(Opoint) || !op->IsInstanceof(Opolygon)) obj = (PolygonObject* )GetDeformedObject(op,doc);
                else obj=(PolygonObject* )op; if(!obj) return TRUE;
            Any ideas? 😞
              On 22/11/2002 at 08:05, xxxxxxxx wrote:
              In your test you are saying:
              If not a point object, OR not a poly object...
              For this test to be false, BOTH parts must be false.
              For both to be false the object must be both a point object and a poly object.
              Poly objects are derived from point objects, so a poly object is also a point object, so this test is equivalent to saying
              If not a poly object...
              which is simpler and clearer.
              The other thing I noted is that you are returning TRUE if 'obj' is NOT valid...
              Hope this helps
                True that. 🙂 But not that bad. thanks anyway
                yes, because the method returns TRUE, so I am returning TRUE too. This will stop the execution of the code anyway. It´s not always FALSE 😉
                Hope this helps
                no not really in my case. The procedure does work, but the returned BaseObject is somehow weird. There must be a fault anywhere in my code, cause after checking the returned object it seems to be completely ok.
                Best
                Samir
