    Matrix Identity
    3 Posts 0 Posters 439 Views
      On 18/06/2014 at 14:42, xxxxxxxx wrote:
      In Blender I can do the following to check if an object has been transformed:
      ident_matrix = Matrix.Identity(4)
      obj_moved = obj.matrix_world != ident_matrix
      I don't see any matrix identity functions in C4D.
      Am I missing something?
      If there isn't, what is the best way to check if an object has been transformed?
      Chris
        On 21/06/2014 at 13:32, xxxxxxxx wrote:
        Couldn't find anything, so I guess you have to roll your own:
        def CheckIdentity(op) :
            matrix = op.GetMg()
            if matrix.off == c4d.Vector(0,0,0) and \n       matrix.v1 == c4d.Vector(1,0,0) and \n       matrix.v2 == c4d.Vector(0,1,0) and \n       matrix.v3 == c4d.Vector(0,0,1) :
                return False
        This does the trick.
          On 21/06/2014 at 15:52, xxxxxxxx wrote:
          This does what I wanted, and is the simplest answer:
          obj.GetMg() == Matrix()
          The function above could be used to check for a particular transformation, but it is overkill for this.
