    Move selected points
    4 Posts 0 Posters 297 Views
      On 12/06/2014 at 01:13, xxxxxxxx wrote:
      Say I have a cube and select the top 4 points. How do I move,rotate, scale that 4 points with python.😊
        On 13/06/2014 at 09:19, xxxxxxxx wrote:
        I came this far:
        Pnt_Obj = doc.SearchObject("Cube")
            Pnts_List = [1,3,5,7]
            for i in Pnts_List:
                Vec = Pnt_Obj.GetPoint(i)
                PosX = Vec.x
                PosY = Vec.y
                PosZ = Vec.z
                Pnt_Obj.SetPoint(i,c4d.Vector(PosX, PosY + Input1, PosZ))
                Pnt_Obj.Message (c4d.MSG_UPDATE)
        The problem is that it do adjust with the slider "Input1" but it just keep on adjusting because it keeps updating the Vector of the points. Please 😢 how do I fix this??
          On 13/06/2014 at 11:11, xxxxxxxx wrote:
          This might help (the actual math). Another "dirty way" is to create a cluster from the selected points rotate the cluster and then kill the object. It's a lot more work to do, and slower, but will get the result you want.
            On 14/06/2014 at 22:36, xxxxxxxx wrote:
            thanks for your reply ShawnFrueh
            will check it out, just thought there could be an easier way to move points around 😢
