    TP IsBorn
    4 Posts 0 Posters 982 Views
      On 16/11/2002 at 11:57, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
         The IsBorn function in the TP_MASTERSYSTEM functions seems to only return true when a particle is first created starting from MinTIme. The PAge TP Node seems to correctly return true when the particle is reborn where the IsBorn function does not. How do I correctly find out if a particle has been born ( or reborn ) correctly using the particle information available from TP_MASTER_SYSTEM?
      Best Regards,  darf
        On 17/11/2002 at 09:15, xxxxxxxx wrote:
        Could you send a scene that shows the correct behavior (of PAge) that you want to get with IsBorn()? I don't know enough TP to recreate this. (For example, what is a reborn particle?)
        Just a guess: perhaps it's possible to deduce this from for example Age() or Life().
        Once I've been able to reproduce the discrepancy between PAge::Born and TP_MASTERSYSTEM::IsBorn(), I'll see if I can find out how the former is implemented.
          On 18/11/2002 at 08:06, xxxxxxxx wrote:
          It seems to work correctly now, I am not sure why it was acting funky. My question now would be how to retrieve a collision event ( not actually reevaluate it ) to be used as a trigger. Any inof would be very helpful!
          Best Regards, darf
            On 20/11/2002 at 11:18, xxxxxxxx wrote:
            No idea. How is it done by users?
