    Can't convert Long to String
    4 Posts 0 Posters 406 Views
      On 07/06/2014 at 08:23, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Platform:      Mac OSX  ;
      Why is it that Xcode keeps telling me that:
      No member named 'IntToString' in 'String'
      in this line:
      GePrint("RGB Loaded:"+String::IntToString(count));
        On 07/06/2014 at 08:40, xxxxxxxx wrote:
        'cause you're using R14. Use LongToString() (global function)
        -Niklas
          On 08/06/2014 at 05:28, xxxxxxxx wrote:
          Howdy,
          in this line:
          This would be an example where the compiler directives I mentioned in the other thread would come in handy to create wrapper functions:
          String MyLongToString(LONG l)
          #if API_VERSION < 15000
              return LongToString(l);
          #else
              return String::IntToString(l);
          #endif
          Then you'd simply call:
          GePrint("RGB Loaded:"+MyLongToString(count))
          ...and compile for all versions.
          Adios,
          Cactus Dan
            On 08/06/2014 at 06:02, xxxxxxxx wrote:
            Yes, you are absolutely right, Dan 🙂
            I still have to start creating all those utility wrappers.
