    Render Shader to image
    4 Posts 0 Posters 464 Views
      On 03/06/2014 at 09:18, xxxxxxxx wrote:
      I am trying to figure out how to take a shader such as the fusion or layer shader and save the output as a an image file. I've noticed the c4d.BaseShader has an example in the doc but does not work with any shaders other than Xbitmap.
      material = doc.GetFirstMaterial()
      shader = material[c4d.MATERIAL_COLOR_SHADER]
      irs = render.InitRenderStruct()
      if shader.InitRender(irs)==c4d.INITRENDERRESULT_OK:
          bitmap = shader.GetBitmap()
          shader.FreeRender()
          if bitmap is not None:
              bitmaps.ShowBitmap(bitmap)
      Does anyone know of any examples that show how this can be done?
        On 03/06/2014 at 22:02, xxxxxxxx wrote:
        The docs are pretty clear about what GetBitmap() does:
        Returns the bitmap of shaders of type Xbitmap, otherwise None.
        <[URL-REMOVED]#BaseShader.GetBitmap>
        Use Sample() to get the color for a pixel and write this to a new Bitmap.
        -NIklas
          On 04/06/2014 at 08:40, xxxxxxxx wrote:
          Thanks for the help Niklas.
          So I think I have the initial idea down as to getting the pixel information using the following code:
          from c4d import Vector, bitmaps
          from c4d.modules.render import ChannelData, InitRenderStruct
              w = 10
              h = 10
              mat = doc.GetActiveMaterial()
              mati = mat[c4d.MATERIAL_COLOR_SHADER]
              irs = InitRenderStruct()
              mati.InitRender(irs)
              cd = ChannelData()
              cd.p = Vector(.5, .5, .5)
              print mati.Sample(cd)
              bitmap = bitmaps.BaseBitmap()
              bitmap.FlushAll()
              bitmap.Init(w,h, depth=8,flags = 0)
              pos = [1,1]
              col = [200,200,200]
              bitmap.SetPixel(pos[0],pos[1],col[0],col[1],col[2])
          When I show the bitmap however it is all black, am I missing something?
            On 04/06/2014 at 12:36, xxxxxxxx wrote:
            Ok I figured it out!
            For anyone trying to do the same here is some code to get you started. (so far it's working 🙂)
            from __future__ import division
            from c4d.bitmaps import ShowBitmap
                w = 100
                h = 100
                shader = mat[c4d.MATERIAL_COLOR_SHADER]
                cd = ChannelData()
                cd.p = Vector(.5,.5,0)
                bmp = bitmaps.BaseBitmap()
                bmp.Init(w,h,24)
                print shader.Sample(cd)
                for x in xrange(w) :
                    for y in xrange(h) :
                        PX = x/w
                        PY = y/h
                        cd.p = Vector(PX,PY,0)
                        s = shader.Sample(cd)
                        r = int(s.x * 255)
                        g = int(s.y * 255)
                        b = int(s.z * 255)
                        bmp.SetPixel(x, y, r, g, b)
                shader.FreeRender()
                ShowBitmap(bmp)
