    Xpresso node in Python. Possible?
    7 Posts 0 Posters 756 Views
      On 30/05/2014 at 05:51, xxxxxxxx wrote:
      Is is possible to create an Xpresso node in Python?
        On 30/05/2014 at 06:19, xxxxxxxx wrote:
        Hi Rui,
        you can create a node with this code:
          XP=c4d.BaseTag(c4d.Texpresso) # create the xpresso tag
          op.InsertTag(XP) # add the xpresso tag
          Node_M=XP.GetNodeMaster()
          # now create the object node
          Bas_Node=Node_M.CreateNode(Node_M.GetRoot(), c4d.ID_OPERATOR_OBJECT, None, 330, 200 )
        you´ll find more informations here:
        <[URL-REMOVED]#GvNode.SetOperatorContainer>
        Martin
          On 30/05/2014 at 07:18, xxxxxxxx wrote:
          I don't mean creating an already existing node inside an Xpresso tag.
          I mean, is it possible to create a new node, just like I can create new tags and objects plugins?
            On 30/05/2014 at 08:01, xxxxxxxx wrote:
            With this you have to define your ports an stuff like this by yourself than:
            Bas_Node=Node_M.CreateNode(Node_M.GetRoot(), c4d.ID_GV_OPERATOR_DUMMY, None, 330, 200 )
              On 30/05/2014 at 08:07, xxxxxxxx wrote:
              But how can I create a python plugin that is placed in the plugins folder that will appear as a new node in the nodes list of Xpresso?
                On 30/05/2014 at 09:44, xxxxxxxx wrote:
                It's not possible with Python (state R15).
                  On 31/05/2014 at 04:48, xxxxxxxx wrote:
                  Damn!! 😞
                  Thank you, Niklas.
