    Threads and CallCommands
    5 Posts 0 Posters 561 Views
      On 22/05/2014 at 11:36, xxxxxxxx wrote:
      Is it possible to use a c4d.CallCommand() In A thread?
      Here is a small snipet of my code:
      import c4d,time
      from c4d import gui
      import socket
      class RB_Client(c4d.threading.C4DThread) :
          global Cthread
          def Main(self) :
              print "Before"
              c4d.CallCommand(12099) # Render to Picture Viewer
              print "After"
      global Cthread
      Cthread = RB_Client()
      Cthread.Start()
      This should send the current scene to render in the picture viewer, instead it is ignored/nothing happens. Any help on this would be great!
        On 22/05/2014 at 14:40, xxxxxxxx wrote:
        No, it is not. The command would be executed in that other thread, too. Command plugins are
        meant to be executed in the main thread.
        Take a look at "Call function from main thread".
          On 27/05/2014 at 14:11, xxxxxxxx wrote:
          Would you happen to know if there are any example plugins that use the c4d.SpecialEventAdd()? Or if there is an alternate way to tell Cinema to start rendering from within a thread?
          Thanks.
            On 28/05/2014 at 01:43, xxxxxxxx wrote:
            I don't know of examples that do, but you'll get the ID you pass to SpecialEventAdd()
            passed to the CoreMessage() method of a GeDialog or MessageData plugin.
            I would've told you if there is. 😉
            Btw, here's how I do it in the PV Render Queue plugin. I use the GeDialog.Timer()
            method to check if the renderer is still running, and if it is not, start a new rendering.
            No thread needed therefore.
                def Timer(self, msg) :
                    rendering = c4d.CheckIsRunning(c4d.CHECKISRUNNING_EXTERNALRENDERING)
                    if self.active_queue and not rendering:
                        file\_ = None
                        for file\_ in self.files:
                            if not file\_.done: break
                        if file\_ and not file\_.done:
                            self.RenderFile(file\_)
                            self.tree.Refresh()
                            self.active_queue = False
                            self.UpdateUI()
            -Niklas
              On 28/05/2014 at 06:59, xxxxxxxx wrote:
              Thanks for the help Niklas.
