    Colorize OM icons?
    3 Posts 0 Posters 382 Views
      On 16/05/2014 at 13:09, xxxxxxxx wrote:
      Cinema 4D Version:   R13+
      Howdy,
      Is it possible to colorize the object icons in the Object Manager, like the native joints in R13+?
      I did a search for "colorize icon" but came up with nothing. Confused
      Adios,
      Cactus Dan
        On 18/05/2014 at 01:49, xxxxxxxx wrote:
        Hi Dan,
        It is possible, we did this in our original release of X-Particles. The user could choose a colour from a description element and colorize an object's icon with that. It worked fine, but we dropped it in later versions - I can't remember why now!
        What we did was have a monochrome image for the object icon. Then the user colour was multiplied into that to recolour the icon. The code from Message() in the ObjectData plugin looked like this:
        Bool XSystem::Message(GeListNode *node, LONG type, void *data)
             BaseDocument *doc;
             BaseContainer *nodebc;
             BaseObject *op = (BaseObject* )node;
             LONG x, y;
             GetCustomIconData *cid;
             UWORD r, g, b;
             Real pixr, pixg, pixb;
             Filename sysic;
             Vector colicn;
             nodebc = op->GetDataInstance();
             doc = node->GetDocument();
             switch(type)
             case MSG_GETCUSTOMICON:
                  cid = (GetCustomIconData* )data;
                  if(cid)
                       colicn = nodebc->GetVector(XOVM_ICONCOLOR); // description COLOR element
                       GetIcon(OXPSystemIcon, cid->dat);           // OXPSystemIcon registered in main.cpp
                       sysic = GeGetPluginPath() + Filename("res") + Filename("sysicon.tif");            // monochrome icon for this object
                    // sysbm is a BaseBitmap class-level variable AutoAlloc'ed in the class definition
                       if(sysbm && sysbm->Init(sysic) == IMAGERESULT_OK)
                            for(y = 0; y < 32; y++)
                                 for(x = 0; x < 32; x++)
                                      sysbm->GetPixel(x, y, &r;, &g;, &b;);
                                      pixr = Real(r) /255 * colicn.x;
                                      pixg = Real(g) / 255 * colicn.y;
                                      pixb = Real(b) / 255 * colicn.z;
                                      r = (pixr * 255);
                                      g = (pixg * 255);
                                      b = (pixb * 255);
                                      sysbm->SetPixel(x, y, (LONG)r, (LONG)g, (LONG)b);
                            cid->dat->bmp = sysbm;
                            cid->filled = TRUE;
                  break;
        //.... etc.....
        The crucial things are the monochrome icon to start with and that you must be able to get its bitmap. I registered the icon in main.cpp to make that easy.
        Steve
          On 19/05/2014 at 06:03, xxxxxxxx wrote:
          Howdy,
          Thanks. 😉
          Adios,
          Cactus Dan
