    Is this possible with python
    9 Posts 0 Posters 784 Views
      On 14/05/2014 at 21:45, xxxxxxxx wrote:
      Can you create a polygon object from a file(Text file)
      if I have the polygon structure of a object and put it in a Text File, can I recreate it with python from that Text File.
      Is this even possible ????
        On 15/05/2014 at 01:54, xxxxxxxx wrote:
        Of course, read the file with all the information and create the object based on that input.
        E.g. a cube shaped object could be like:
                recube = c4d.BaseObject(c4d.Opolygon)
              recube.ResizeObject(8,6)		#8 vertexes (points) and 6 polygones
              recube.SetPoint(0,vertex1)
              recube.SetPoint(1,vertex2)
              recube.SetPoint(2,vertex3)
              recube.SetPoint(3,vertex4)
              recube.SetPoint(4,vertex5)
              recube.SetPoint(5,vertex6)
              recube.SetPoint(6,vertex7)
              recube.SetPoint(7,vertex8)
                recube.SetPolygon(0,c4d.CPolygon(0,1,2,3))
              recube.SetPolygon(1,c4d.CPolygon(4,5,1,0))
              recube.SetPolygon(2,c4d.CPolygon(7,6,5,4))
              recube.SetPolygon(3,c4d.CPolygon(3,2,6,7))
              recube.SetPolygon(4,c4d.CPolygon(1,5,6,2))
              recube.SetPolygon(5,c4d.CPolygon(0,4,7,3))
              recube.Message (c4d.MSG_UPDATE)
          This code above I want python to read it for me from a file and then create a object from it.
            On 15/05/2014 at 07:58, xxxxxxxx wrote:
            I think I can explain better: _<_img src="http://www.c4dcafe.com/ipb/public/style_emoticons/default/oops.gif" border="0" alt=":oops:" title=":oops:" /_>_
            I want to do these steps in python:
            1] Create a empty polygon
            2] Import the points from a ASCII File
            3] Import the polygons from a ASCII File
            Basically build the object from these steps in python
            I see you can almost achieve this with call commands
            c4d.CallCommand(13039)            # Empty Polygon Object
                c4d.CallCommand(12530)            # Points mode in Structure
                c4d.CallCommand(13018)            # Import ASCII Data (Points)
                c4d.CallCommand(12532)            # Polygons mode in Structure
                c4d.CallCommand(13018)            # Import ASCII Data (Polygons)
              On 16/05/2014 at 01:25, xxxxxxxx wrote:
              Sorry, is this working for you or do you still have some questions?
                On 16/05/2014 at 01:38, xxxxxxxx wrote:
                I still need help 😢
                refer to my second post
                  On 16/05/2014 at 04:08, xxxxxxxx wrote:
                  Ok, here a small example how to read ascii data.
                  #the world of Python in CINEMA 4D
                  from c4d import storage, gui
                  # read ascii file and create object
                  def ReadAscii() :
                      pointFile = "D:\Users\pgrooff\Documents\pim\c4d R15\import -export ascii\simple cube.txt"
                      try:
                          fpoints = open(pointFile)
                      except IOError, e:
                          gui.MessageDialog(e)
                      polysFile = "D:\Users\pgrooff\Documents\pim\c4d R15\import -export ascii\simple cube polys.txt"
                      try:
                          fpolys = open(polysFile)
                      except IOError, e:
                      #split the file into line list
                      lines = fpoints.readlines()
                      #how many lines? so points
                      nrPoints = len(lines)
                      linesPolys = fpolys.readlines()
                      #how many lines? so polys
                      nrPolys = len(linesPolys)
                      #-1 for first line
                      print "Nr points-polys: ", nrPoints-1, nrPolys-1
                      #create polygon object with point count of lines and count of polygons
                      recube.ResizeObject(nrPoints-1, nrPolys-1)
                      #Points
                      for i, line in enumerate(lines) :
                          #split line into components
                          coord = line.split(",")
                          #ignore corrupt csv line
                          if len(coord)<4: continue
                          try:
                              nr = int(coord[0])
                              x = float(coord[1])
                              y = float(coord[2])
                              z = float(coord[3])
                          except ValueError, e:
                              continue
                          recube.SetPoint(i-1,c4d.Vector(x,y,z))
                          print "Point inserted: ", i-1,x,y,z
                      #Polys
                      for i, line in enumerate(linesPolys) :
                          if len(coord)<5: continue
                          try:
                              nr = int(coord[0])
                              p1 = int(coord[1])
                              p2 = int(coord[2])
                              p3 = int(coord[3])
                              p4 = int(coord[4])
                              continue
                          recube.SetPolygon(nr,c4d.CPolygon(p1,p2,p3,p4))
                          print "Poly inserted: ", nr,x,y,z
                      doc.InsertObject(recube)
                      ReadAscii()
                  I used the following input files. One for points and one for the polys.
                  I got these files by exporting a cube data to these files.
                  Later I edited the files, to add some ",".
                  But you can choose the format you want.
                  Point file:
                  Point	X	Y	Z
                  0,	-100,	-100 ,	-100
                  1,	-100 ,	100 ,	-100
                  2,	100, 	-100 ,	-100
                  3,	100 ,	100 ,	-100
                  4,	100 ,	-100 ,	100
                  5,	100 ,	100, 	100
                  6,	-100, 	-100, 	100
                  7,	-100 ,	100 ,	100
                  Polygon file:
                  Polygon	A	B	C	D
                  0,	0,	1,	3,	2
                  1,	2,	3,	5,	4
                  2,	4,	5,	7,	6
                  3,	6,	7,	1,	0
                  4,	1,	7,	5,	3
                  5,	6,	0,	2,	4
                    On 16/05/2014 at 04:42, xxxxxxxx wrote:
                    Thanks pgroof  _<_img src="http://www.c4dcafe.com/ipb/public/style_emoticons/default/thisrocks.gif" border="0" alt=":thisrocks:" title=":thisrocks:" /_>_
                    Will look at it tonight in detail
                      On 16/05/2014 at 05:26, xxxxxxxx wrote:
                      Thanks pgroof you _<_img src="http://www.c4dcafe.com/ipb/public/style_emoticons/default/thisrocks.gif" border="0" alt=":thisrocks:" title=":thisrocks:" /_>_
                      Exactly what I was looking for&n;_<_img src="http://www.c4dcafe.com/ipb/public/style_emoticons/default/signthankspin.gif" border="0" alt=":signthankspin:" title=":signthankspin:" /_>_" />
