    Using all processors
    6 Posts 0 Posters 520 Views
      On 12/05/2014 at 12:03, xxxxxxxx wrote:
      With a python tag plugin, I'm calculating voxels, so a lot of polygon handing.
      Now I see that cinema is not using all processors (only 1 out of 4) on my Windows 7 machine.
      When rendering it uses all processors, but not with my python tag plugin.
      What to do, so that cinema will use all processors?
        On 12/05/2014 at 12:58, xxxxxxxx wrote:
        It's a CPython Limitation, read up on the GIL and Multiprocessing in Python.
        -Niklas
          On 13/05/2014 at 01:08, xxxxxxxx wrote:
          So, in C++ cinema uses uses all / more processors?
          -Pim
            On 13/05/2014 at 01:36, xxxxxxxx wrote:
            Hi pgrooff
            I guess that´s why e.g. supervoxels was written in c++.
            http://www.remotion4d.net/redokuwiki/doku.php?id=supervoxels2013
            Funny, I also created a voxelizer in the past few days.
            cheers
            Martin
              On 13/05/2014 at 06:07, xxxxxxxx wrote:
              Yes, it is quite a challenge, but fun.
              The main challenge is to optimize, improve the algorithm step by step.
              I am doing a prototype in python and then port it to C++.
              One of the things I like to do with the voxels, is to explode volumetric objects.
              Also with "supervoxels" you have threading option / nr of cores options.
              Very advanced and interesting. But I guess you can divide the processing in parts and assign that to different threads (processors?).
              I saw your new post sharing your voxelizer. Great thanks.
              I do not use particle, but straight forward cubes.
              -Pim
                On 14/05/2014 at 01:39, xxxxxxxx wrote:
                I´ve never used threads before and I´m not sure if I understand this right.
                If I open a new thread in c4d, is it only a user thread and not a Kernel thread?
                Does that mean that I'm only working on one Kernel and I just delegate tasks to several User threads?
                And is this the right usage, cause within the function it says that I´m still using the Main thread?
                from c4d.threading import C4DThread
                class firstThread(c4d.threading.C4DThread) :
                  k=0
                  def func1(self,k) :
                      print  c4d.threading.GeIsMainThread(),"main"
                      for i in xrange(1,8000) :
                          x=1000000/i
                          for j in xrange(1,1000) :
                              y=1000000/j
                              k=x*y
                      print c.IsRunning(),"first inside"
                      return k
                class secondThread(c4d.threading.C4DThread) :
                  o=0
                  def func2(self,o) :
                          x=1000000/i
                              y=1000000/j
                              o=x*y
                      return o
                c= firstThread()
                d= secondThread()
                #Start Threads
                c.Start()
                k= 0
                print c.IsRunning(),"first"
                k= c.func1(op)
                d.Start()
                o= 0
                print d.IsRunning(),"second"
                o= d.func2(op)
                c.End()
                d.End()
                print o+k
                Martin
