    Problem with ScreenToWorld Conversion
    7 Posts 0 Posters 1.4k Views
      On 12/11/2002 at 10:11, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      When using the GeRayCollider Library and I determine a Ray->Edge Detection I am using the current Mouse Position that I got from the &msg BaseContainer in the Mouse Input Method and Convert the Screen Coords into World Coords. But it seems I am doing something wrong, because when I rotate the editor view the point I have set is actually not on my edge but anywhere in the space.
      Col = bd->SW(Vector(mx,my,0));
      is what I am using to convert the point to world space.
      Any idea why it is wrong?
      thanks
        On 12/11/2002 at 10:14, xxxxxxxx wrote:
        I guess I got it. Now I´m using the distance instead of 0 for Col.z.
        but if somebody has a better idea? I´m open. 🙂
          On 12/11/2002 at 10:44, xxxxxxxx wrote:
          Hmm, it is still not exact enough 😕 Does anybody know how to get the exact ScreenToWorld conversion?
          Thanks in advance
            On 12/11/2002 at 11:40, xxxxxxxx wrote:
            Could you define what you mean by "ScreenToWorld conversion" and describe how BaseView::SW() fails to be exact by this definition?
              On 12/11/2002 at 12:30, xxxxxxxx wrote:
              The problem is that when I am near an edge with the mouse pointer in screen space, then the barycentric coords get close to 0.0. Ok so I am checking if they are smaller than 0.02. If so I store the position of the mouse pointer in i.e. Col = bd->SW(Vector(mx,my,res.distance));
              Looking into the editor view I can see that the XORLine is drawn (the way I want it) on the edge. But when I rotate the view I can actually see that the XORLine (or rather the World Coordinates that I got from the conversion) is not drawn on the edge but under the edge or beside it or or or. And it´s not close enough to the edge! That is the problem. If the barrycoords are so close and I am right over the edge with the mouse, why is the world position after conversion not on the edge or at least pretty close to it? With these Coords of Col I can´t do nothing. They are not exact enough. D
              That is my problem. Any ideas?
              Thanks Samir
                On 12/11/2002 at 14:01, xxxxxxxx wrote:
                Use the real position instead: "obj->GetMg() * res.hitpos".
                  On 13/11/2002 at 00:24, xxxxxxxx wrote:
                  Oh my god, why didn´t that come to MY mind? You´re the man!
                  Thanks very much Mikael. You saved my a.... further developement. 😉
                  Best
                  Samir
