UserData button
On 06/05/2014 at 15:20, xxxxxxxx wrote:
I created a button through UserData with:
UD=c4d.GetCustomDataTypeDefault(c4d.DTYPE_BUTTON)
UD[c4d.DESC_NAME] = "Press Me"
UD[c4d.DESC_CUSTOMGUI] = c4d.CUSTOMGUI_BUTTON
node.AddUserData(UD)(actually, I created more than one button)
Now, how can I check what button was pressed.
I believe it is inside the Message method but... how?! -
On 07/05/2014 at 02:43, xxxxxxxx wrote:
I think it is:
NodeData.Message(self, node, type, data)MSG_DESCRIPTION_COMMAND Sent by for example BUTTON (description element). See example[URL-REMOVED] below._<_t_>_
On 07/05/2014 at 03:43, xxxxxxxx wrote:
I had tried that but it returns me the same value, no matter what button I press
I used this code to check it out:
def Message(self, node, type, data) :
if type==c4d.MSG_DESCRIPTION_COMMAND:
bt = data['id'][0].id
print bt -
On 07/05/2014 at 07:55, xxxxxxxx wrote:
Here is how I do it in C++ (sorry).
I assume you already check this forum.
There are multiple posts about e.g. MSG_DESCRIPTION_COMMANDBool SolarObject::Message(GeListNode* node, Int32 id, void* data) { switch (id) { case MSG_DESCRIPTION_COMMAND: // MSG_DESCRIPTION_COMMAND is send when button is clicked { DescriptionCommand *dc = (DescriptionCommand* )data; //data contains the description ID of the button Int32 button = dc->id[0].id; //Get the ID of the button //GePrint ("MSG_DESCRIPTION_COMMAND: " + String::IntToString(button)); switch (button) //Check for different button IDs { case SETKEY: // set keyYou can also try checking for MSG_DESCRIPTION_CHECKUPDATE
case MSG_DESCRIPTION_CHECKUPDATE: // MSG_DESCRIPTION_CHECKUPDATE is send UD field is clicked { //BaseContainer *data = ((BaseObject* )node)->GetDataInstance(); DescriptionCheckUpdate *dcu = (DescriptionCheckUpdate* ) data; Int32 button = dcu->descid[0][0].id; -
On 07/05/2014 at 07:58, xxxxxxxx wrote:
I don't understand why you can't get it's value just like any other UserData gizmo?
This script that will create a UD button to an object:
import c4d def main() : obj = doc.GetFirstObject() if not obj: return False bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL) #Create the default container bc.SetString(c4d.DESC_NAME,"Click Me") #The text on the button bc.SetLong(c4d.DESC_CUSTOMGUI,c4d.CUSTOMGUI_BUTTON) #Sets the bool gizmo to be a button button = obj.AddUserData(bc) #Add the userdata to the object obj[button] = False #Assign a default value to it when it created c4d.SendCoreMessage(c4d.COREMSG_CINEMA, c4d.BaseContainer(c4d.COREMSG_CINEMA_FORCE_AM_UPDATE)) c4d.EventAdd() if __name__=='__main__': main()To get it's value this should be all you need to do.
#Since the button gimzo was the first UD item created #It has a level ID #1 btnValue = obj[c4d.ID_USERDATA,1] #<---Returns true/false depending on the button's click state print btnValueEach new button should have it's own level#.
So you just use that number instead of #1 in the code for getting the value of the other buttons.Are you doing something different than this Rui?
On 07/05/2014 at 11:08, xxxxxxxx wrote:
It worked great!!
Thank you, Scott.
I just had to make sure that after reading the value I set the value back to False.
Now I just need to know how to change the name of the UserData tab into another thing.
And, how to simulate multi-column groups of UD parameters programmatically.
