    SetSelection
    5 Posts 0 Posters 1.6k Views
      On 11/11/2002 at 13:56, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Oh man, it really seems I have to relearn anything again that I have used in COFFEE. Sorry, for the frequent questioning. (I guess that will happen more often in the next few days)
      How can I set a selection in C++? I know there is a FromArray() Command that selects the elements of an Unsigned CHAR selection, but to be honest I have no clue how to use that.
      But isn´t there something that uses a BaseSelection to set a Selection? Like in COFFEE I mean. bs->Select(i); op->SetPointSelection(bs); or anything similar to that?
      Thanks again
        On 11/11/2002 at 15:20, xxxxxxxx wrote:
        Forget it. I got it now. Fight night. 🙂
        Samir
          On 12/11/2002 at 01:30, xxxxxxxx wrote:
          Could you post an example how to normally select some points? I have some problems to be honest. The way I´m doing it now is:
          BaseSelect *vs = ToPoly(op)->GetPointS();
          UCHAR *Sel = bNew UCHAR[counter];
          for(i;i<counter;i++)
                    if(i==1)Sel[i-1]=(UCHAR)tboon;
          vs->FromArray(Sel,counter);
          bDelete(Sel);
          But I got somehow problems. tboon (etc.) stores a vertex index. So I want to select the point in tboon. I am really sure that I am doing it wrong (because of GetPointS). Is there a easier way? :
            On 12/11/2002 at 06:05, xxxxxxxx wrote:
            Simple way: you can use Select(i) or Deselect(i).
            Must be "for(i=0;i<counter;i++)" or you set "i" before?
                for(i=0;i<count;i++)
                if(mustselect(i)) Sel[i] = 1;
                else Sel[i] = 0;
            It must work.
            Remotion.
              Oh, that works? Great. Thanks for your help Remo.
              Yep, set it before the loop.
              Best
              Samir
