    how to XOR
    6 Posts 0 Posters 571 Views
      On 19/04/2014 at 07:09, xxxxxxxx wrote:
      I can XOR a vector
      pxvec = pxvec ^ vecmask
      how do I XOR a single axis
      pxvec.x = pxvec.x  ????  vecmask.x
      tia
        On 19/04/2014 at 09:42, xxxxxxxx wrote:
        pxvec.x = pcvec.x * vecmask.x
        Vector XOR just multiplies componentwise.
        -Niklas
          On 22/04/2014 at 04:35, xxxxxxxx wrote:
          thanks
          I couldn't make sense of the SDK syntax '__rxor__(self,other)'
          or the example
          I thought % was a modulo operator?
          Vector.\__rxor\_\_(self, other)[](file:///Users/paultaylor/Documents/Media/3D/Programming/Python/CINEMA4DR15037PYTHONSDKHTML20130823.zip%20Folder/help/modules/c4d/Vector/index.html?highlight=xor#Vector.__rxor__)
          Multiplies two vectors together componentwise and set the left hand vector to the result:
          v_result = c4d.Vector(1,2,3)%c4d.Vector(2,3,4)
          #v_result => Vector(2,6,12)
          _<_t_<__<_t_>_<_<_t_>_lgroup>Param : The other argument.
          Return type: Vector[URL-REMOVED]
          Retu_<_t_>_
            On 22/04/2014 at 09:09, xxxxxxxx wrote:
            Well, that's a typo in the docs. The modulo operator performs the cross product.
            Thanks for the notice.
            -Niklas
              On 23/04/2014 at 11:43, xxxxxxxx wrote:
              So how do you form this with the example above pls?
              can't figure the syntax
              xvec.x = pcvec.x__rxor__(vecmask.x)
              tia
                On 24/04/2014 at 03:15, xxxxxxxx wrote:
                I don't get what you are trying to do. Vector.__rxor__() is only called in some special cases, see
                https://docs.python.org/2/reference/datamodel.html#object.\__rxor\_\_
                If you want to multiply two vectors componentwise, use the ^ operator. The * operator on Vectors
                performs the dot-product. If you want to multiply one component of a vector with another, use
                the * operator. You can't multiply a  vector component componentwise as there is only one component
                which is the value itself.
                -Niklas
