    How to delete polygons?
    4 Posts 0 Posters 392 Views
      On 18/04/2014 at 14:42, xxxxxxxx wrote:
      I'm selecting random polygons from an object, depending on a percentage with this code:
      random.seed(rand)
      selection=op.GetPolygonS()
      selection.DeselectAll()
      pnum=op.GetPolygonCount()
      for i in range(pnum) :
          rnd1=random.random()
          if rnd1<kill:
              selection.Select(i)
      This part seems to be working fine.
      But when I call the delete command with
      c4d.CallCommand(12109)
      I get a crash!!
      So, how can I delete the selected polygons?
      Oh, the op object in not in the document. It is an object created inside my code.
        On 18/04/2014 at 15:04, xxxxxxxx wrote:
        Ok, nevermind... I just used the SendModelingCommand command to delete the polygons instead of the CallCommand and it worked fine.
          On 18/04/2014 at 15:08, xxxxxxxx wrote:
          You might have to use a temp doc in memory as a workshop area to construct and delete the polygons in your object.
          Then copy it to the active document and kill the temp doc when you're finished.
          Oops..I wasn't fast enough. 🙂
            On 18/04/2014 at 15:34, xxxxxxxx wrote:
            Thank you, Scott.
            Your solution may come in handy for other types of things, though 🙂
            Rui Batista
