    Custom Node, LinkBoxGUI
    2 Posts 0 Posters 334 Views
      On 14/04/2014 at 07:18, xxxxxxxx wrote:
      Cinema 4D Version:   14
      I am testing My Own Licence Server Plugin.
      It has Group Node, Client Node, Serial Node, each TreeView.
      I can't figure out how to set Custom BaseList2D node to LinkBox Gui when Node is made by AllocListNode(). When I Set node to LinkBox, it's name is empty.
      Following image show LinkGUI's Data(Custom Node2) in there, But LinkBox's name is empty.
      And Pop-up list(Clear) disabled.
      1. Drag to LinkBox.
      2. And LinkBox has link's description, but name is gone.
      So, I had tests some situation.
      1. Object Cube in Document is work fine. (Getting Ocube by GetActiveObject())
      2. Object Cube not in Document is not works. (Ocube Made by BaseList::Alloc())
      3. My Custom Node is same that Object Cube not in Document.
      ...Must be In Document?
      4. But, Licence Server's Serial Module works fine when
      I Drag it to My Custom Node's LinkBox GUI.
      ... C4D's Licence Server R13's Serial Module is not BaseObject. So, it is not in Document.
      What is my missing point?
      I made tiny example for you. It is not deal with Two Custom Node, But maybe It's phase same.
      https://googledrive.com/host/0B1SFMskowpq-TXFaQlpqUlcxejQ/upload.zip
      -elasticmind
        On 17/04/2014 at 14:51, xxxxxxxx wrote:
        Your conclusion is correct, a node must be in the Document so that it can be used in a LinkBox GUI.
        Take a look at NodeData::GetBranchInfo(). This is the place where you can expose your nodes to
        the Document. It must be implemented in a node that is already in the document (a SceneHook is
        used for this situation usually).
        Best,
        -Niklas
