    Frame selected object/Geometry not working
    4 Posts 0 Posters 449 Views
      On 09/04/2014 at 14:20, xxxxxxxx wrote:
      For my script purpose i need to frame the first object  that i have merged in my scene before rendering.
      this 2 commands c4d.CallCommand(12148) # Frame Geometry c4d.CallCommand(13038) # Frame Selected Elements  do not frame the object in the viewport. It seem over-zoomed on the object...
      If i paste one of these command in the console , there it frame wellthe object...
      Any idea how to make it works?
      for infile in glob.glob(scenesPath+"\*.c4d") :
                  fname, ext = os.path.splitext(infile)
                  c4d.documents.LoadFile(refPath+'\param.c4d')
                  docview=doc.GetActiveBaseDraw()
                  c4d.documents.MergeDocument(doc,infile,c4d.SCENEFILTER_OBJECTS|c4d.SCENEFILTER_MATERIALS|c4d.SCENEFILTER_DIALOGSALLOWED|c4d.SCENEFILTER_MERGESCENE)
                  mycam=docview.GetSceneCamera(doc)
                  mycam.SetFocus(35)
                  obj=doc.GetFirstObject()
                  doc.SetActiveObject(obj)
                  obj.Message(c4d.MSG_UPDATE)
                  macam.SetFocus(25)
        On 17/04/2014 at 12:33, xxxxxxxx wrote:
        It is not clear to me what your problem is. Could you narrow your problem down and provide
        a script that can be pasted into the script manager that will demonstrate the problem?
        Best,
        -Niklas
          On 18/04/2014 at 13:06, xxxxxxxx wrote:
          i think i've found why it does not works properly. In fact when i load scene and merge with my python script, the viewport is "empty" untill my function finish. So the command "Frame selected object" apply to nothing. I should find a way to force the viewport to refresh and then call this command. I'm searching to make this not a dirty way... i will let you know if i find the solution, excetp if you tell me it before 😄
            On 21/04/2014 at 09:04, xxxxxxxx wrote:
            Simple refresh is c4d.EventAdd()
