    Announcing GitHub PluginCafe BETA
    19 Posts 0 Posters 2.4k Views
      On 09/04/2014 at 01:42, xxxxxxxx wrote:
      Hi Moustach,
      I have added the information about c4dmake, which I should have included in the first place, to the
      repository. The thing is that c4dmake is not an officially supported way to compile the Cinema 4D API and
      Plugins. There is someone else working to create the Visual Studio and XCode project files so they can be
      released soon.
      I am sorry for the inconveniences, but as stated, the project is doing its first steps. Please also redownload
      the repository as I have made a few tiny changes today so your copy is in sync and it won't introduce
      minor misunderstandings.
      That being said, on a non-official note, as I am the developer and maintainer of c4dmake, you
      first have to install c4dmake as described here. I personally am only developing using c4dmake and use
      no IDE. That is also why I can't create the project files for Visual Studio and XCode myself.
      Best,
      -Nikas
        On 09/04/2014 at 11:12, xxxxxxxx wrote:
        Hey Niklas,
        Thank you for your answer, I'll look more into it tonight!
          On 24/04/2014 at 10:59, xxxxxxxx wrote:
          Hi - this is very exciting news! That said, and maybe this is lack of experience with GitHub, but I'd like some middle ground between the current SDK documentation, and the GitHub system.
          What I'm missing:
          * A list of a SDK accessible classes/functions as you see in our current documentation.
          * Syntax highlighting of the SDK examples (specifically Python examples) online.
          * A cleaner link between the Q&A; format of PluginCafe and the code examples of the SDK. Perhaps something closer to StackOverflow?
          I think a lot of this could be accomplished by taking the current SDK docs and using something more akin to a Wiki format, so that we can add examples and explanation to the classes/methods listed.
            On 24/04/2014 at 14:05, xxxxxxxx wrote:
            I finally tried, it works great!
            Thanks!
              On 25/04/2014 at 14:24, xxxxxxxx wrote:
              Hi Moustach, thanks for telling us. Would be bad if not 🙂
              Thanks for your feedback, Donovan.
              @1: Which classes/functions and where would you like them to be listed?
              @2: I've sent a message to the GitHub support already (see #4)
              @3: We'll be looking at it. 😉
              -Niklas
                On 25/04/2014 at 17:44, xxxxxxxx wrote:
                Hey Niklas,
                Perhaps I'm not totally clear on the goals of this project. Is the GitHub Repo meant to replace the current SDK documentation[URL-REMOVED] or is it supposed to be a supplement?
                If it's meant to replace the docs, then there are a lot of nice things about the docs that the GitHub repo doesn't currently address:
                * A general introduction to programming in C4D
                * Links to helpful websites/books/etc
                * A list of all SDK accessible classes & methods
                * A searchable list of keywords
                * Short examples (albeit few and far between) of how to use various methods right below their definition.
                If the goal of the repo is to supplement the current docs, then I'd really like for there to be an easy way to point people from the current docs to all of the examples in the GitHub SDK where a given class/method is used. Ideally that would probably be something like wiki-editable docs, or a comments thread under each method where people can discuss them.
                I think that the GitHub wiki would be a good place to start adding an FAQ section, and list of helpful tutorials, etc.
                Also, there's a fair amount of overlap between the Python & C++ SDKs - because they're currently separate repos, any helpful documentation (about the way that C4D works) will need to be duplicated between the repos.
                I'm not sure how to address these issues, but these are my first impressions.
                -Donovan
                  On 25/04/2014 at 17:46, xxxxxxxx wrote:
                  Oh, and thanks for sending a message to GitHub support - here's hoping they start syntax highlighting for .pyp!
                    On 26/04/2014 at 08:09, xxxxxxxx wrote:
                    Hey Niklas,
                    -Donovan
                    Hi Donovan,
                    It seems like I have been quite inaccurate about the project goals, I'm sorry for the confusion. The
                    SDKs are not meant to replace the documentation! They could never, they're just code examples.
                    They're meant to replace the existing SDKs (being collections of plugin examples) which you can find
                    in the Cinema 4D plugins/ folder for the C++ SKD and in the help/examples/ folder of the Python Docs
                    archive.
                    The code there is mostly rotten and old, little documented and bad structured.
                    We're working on a solution to integrate the SDK repositories with the online documentation already.
                    The GitHub wiki will soon be filled with such stuff, including our coding style guidelines (for which it would
                    be nice if contributors stick to it, but its not absolutely necessary)
                    We will try to keep the examples in sync, meaning that the same example plugin in Python is available
                    in C++ (see the starters/ folder in each repository for instance), but it's not always possible.
                    Best,
                    -Niklas
                      On 26/04/2014 at 08:37, xxxxxxxx wrote:
                      In other words. He's trying to do what I've been doing for years.
                      https://sites.google.com/site/scottayersmedia/plugins
                      Except using GitHub, instead of a static web page.
                      So you guys can also send things in and participate if you would like to contribute to it.
                      I hope it works out better than the last one did: http://c4dprogramming.wordpress.com/
                      That one started out wonderfully. But then died as quickly as it started.
                        On 15/05/2014 at 10:37, xxxxxxxx wrote:
                        Thank god!  I love github!
                          On 31/05/2014 at 23:15, xxxxxxxx wrote:
                          Any news on the Xcode project file?
                            On 16/06/2014 at 03:30, xxxxxxxx wrote:
                            Hi Moustach,
                            sorry for the late reply. Visual Studio 2012 project files have just been added. XCode project
                            files will follow soon.
                            -Niklas
                              On 29/07/2014 at 17:21, xxxxxxxx wrote:
                              Any update on those XCode project files?
                              Thanks!
                              Donovan
