    Tag Plugin, action when user drags into Link
    4 Posts 0 Posters 288 Views
      On 04/04/2014 at 12:50, xxxxxxxx wrote:
      So I have an object in a Link box in the GUI of my tag plugin that once the user has dragged an object into I want to get the y value of that position.
      I am doing processing in the "Execute" function of the inherited "plugins.TagData" class but it is getting the value everytime.
      Where should I add the code to get the object's y position the first time the user drags an object to the link box?  Should I put it in the "Message" function and use the "type" parameter via
      if type==c4d. _MSG_DRAGANDDROP_ :
      If so it doesn't seem to be working.  Any guidance would be very helpful, thanks!
      Jimmy
        On 11/04/2014 at 07:23, xxxxxxxx wrote:
        Just remember when you obtained the value the first time and don't re-obtain it when
        you already have it.
        -Niklas
          On 11/04/2014 at 08:32, xxxxxxxx wrote:
          Niklas,
          You are right, when I first obtain it I write it into a global variable which I don't change.  That solved the issue.
          Jimmy
            On 11/04/2014 at 09:34, xxxxxxxx wrote:
            Global variable? Sounds bad for a tag, what if the tag is there two times?
