    BaseArray
    14 Posts 0 Posters 1.7k Views
      On 03/04/2014 at 08:25, xxxxxxxx wrote:
      This the error message:
      1>d:\program files\maxon\cinema 4d r15 beta\plugins\simple test c++ plugin\basearray_test.cpp(34) : error C2664: 'maxon::BaseArray<T>::Swap' : cannot convert parameter 1 from 'int' to 'maxon::BaseArray<T>::IteratorTemplate<CONSTITERATOR>'
      1>          with
      1>          [
      1>              T=String
      1>          ]
      1>          No constructor could take the source type, or constructor overload resolution was ambiguous
      This the line of code that gives the error:
      Line 34: myBaseArray.Swap(2, eb); //swap elements
      I'm using VS c++ 2010 Express
        On 03/04/2014 at 17:17, xxxxxxxx wrote:
        You may need to cast and/or type your values as ConstIterator instead of Int.
          On 07/04/2014 at 01:01, xxxxxxxx wrote:
          Sorry, I tried a sorts of typecasts, but I did not succeed.
          It keeps telling me Error: identifier "ConstIterator" is unidentified .
          Could you please give me an example.
          Pim
            On 07/04/2014 at 08:34, xxxxxxxx wrote:
            Is Swap() not supposed to used like this ?
            myBaseArray.Swap(myBaseArray[2], myBaseArray[1]);
              On 08/04/2014 at 01:56, xxxxxxxx wrote:
              I read the manual as that you have to supply two indexes in basearray.
              But I think you are right. I give it a try.
              Thanks, Pim
              _<_div ="memproto" style="font-weight: bold; font-size: 14px; line-height: 22px; font-family: roboto, sans-serif; border-top-width: 1px; border-top-style: solid; border-top-color: rgb150, 170, 209; border-left-width: 1px; border-left-style: solid; border-left-color: rgb150, 170, 209; border-right-width: 1px; border-right-style: solid; border-right-color: rgb150, 170, 209; padding: 6px 0px; color: rgb26, 37, 59; text-shadow: rgba255, 255, 255, 0.901961 0px 1px 1px; -: http://kinug.com/c4d/cpp/help/pages/c4d_miscav_f.png; : rgb220, 226, 239; -shadow: rgba0, 0, 0, 0.14902 5px 5px 5px; -webkit--shadow: rgba0, 0, 0, 0.14902 5px 5px 5px; border-top-right-radius: 4px; border-top-left-radius: 4px; -repeat: repeat no-repeat;"_>_void Swap ( Iterator a,
              Iterator b
              ) inline_>
              _<_div ="memdoc" style="font-size: 14px; line-height: 22px; font-family: roboto, sans-serif; border-width: 0px 1px 1px; border-bottom-style: solid; border-bottom-color: rgb150, 170, 209; border-left-style: solid; border-left-color: rgb150, 170, 209; border-right-style: solid; border-right-color: rgb150, 170, 209; padding: 6px 10px 2px; -: http://kinug.com/c4d/cpp/help/pages/c4d_miscav_g.png; -shadow: rgba0, 0, 0, 0.14902 5px 5px 5px; border-bottom-left-radius: 4px; border-bottom-right-radius: 4px; -webkit--shadow: rgba0, 0, 0, 0.14902 5px 5px 5px; -repeat: repeat no-repeat;"_>_epeat no-repeat;">
              Swaps elements a and b (equivalent to global Swap(array[a], array **)
              Parameters
              [in]| a| Position of element to be swapped.
              [in] b Position of elemen_<_t_>_ be swapped.
                On 09/04/2014 at 03:03, xxxxxxxx wrote:
                Have you tried something like this?
                arr.Swap(arr.Begin() + 2, arr.Begin() + 1)
                  On 09/04/2014 at 07:53, xxxxxxxx wrote:
                  This is working:
                  myBaseArray.Swap(myBaseArray.Begin() + 2, myBaseArray.Begin() + 1)
                  This is NOT working:
                    On 09/04/2014 at 15:35, xxxxxxxx wrote:
                    Very strange since the documentation shows the NOT working way as an example.  Maybe we can get some resolution on what is valid and what is not?
                      On 10/04/2014 at 01:50, xxxxxxxx wrote:
                      Yes, indeed strange. Hopefully someone can check / explain.
                      But for now, I have a solution.
                        On 10/04/2014 at 03:59, xxxxxxxx wrote:
                        Could you point me to the link where the BaseArray documentation shows a wrong example?
                        The documentation states that you need an iterator for the position and just using an Int or passing the content of a specific array position (like the OP did in his examples) of course doesn't magically create an iterator (just imagine the swap function would have expected a String as input parameter for the position, then just passing an Int wouldn't work either).
                        You have to pass the expected parameter type - and Niklas showed how to do it properly.
                        Best regards,
                        Wilfried
                          On 10/04/2014 at 18:17, xxxxxxxx wrote:
                          Not a direct example, but it somewhat draws one in the wrong direction if you have no idea about BaseArray::Swap() :
                          Swaps elements a and b (equivalent to global Swap(array[a], array[b]))
                            On 11/04/2014 at 07:07, xxxxxxxx wrote:
                            Reading that, I immediately think of Swap looking like this:
                            template <typename T>
                            void Swap(T& a, T& b) {
                                T c = a;
                                a = b;
                                b = c;
                            Would be of no advantage to define it as a member method if it is declared and implemented
                            like this. I agree, though, that the documentation could elaborate more on swapping.
                            Best,
                            -Niklas
