How to Get a Joint Object from a tag
On 25/03/2014 at 09:18, xxxxxxxx wrote:
So I am coding a python tag plugin and I have a text box that I can drag a joint object to, but how do I pull that data from the text box in code. What type of object should I use to get that data? This is the code I have in the python file
SOURCE_LINK = 1001
FINAL_LINK = 1002def Execute(self, tag, doc, op, bt, priority, flags) :
tag = op.GetFirstTag()
data = tag.GetDataInstance()
pos = op.GetAbsPos()
self.source_cd = c4d.modules.character.CAJointObject()
self.final_cd = c4d.modules.character.CAJointObject()
self.source_cd = data.GetData(SOURCE_LINK)
self.final_cd = data.GetData(FINAL_LINK)My plan is to take the y value of the source joint and apply it to the final joint, Is this the correct way to get that Joint object?
Any thoughts would be greatly appreciated.
Jimmy -
On 25/03/2014 at 13:36, xxxxxxxx wrote:
So it looks as if I've found the solution in the following code.
self.final_cd = c4d.modules.character.CAJointObject()self.source_cd = data.GetData(SOURCE_LINK)
myMatrix = c4d.Matrix()
myMatrix,len = self.source_cd.GetBone()Now off to learn about the Matrix object
