    Spline Shader: Need Help
    6 Posts 0 Posters 636 Views
      On 20/03/2014 at 13:03, xxxxxxxx wrote:
      Cinema 4D Version:   13
      I was talking with PerAnders on CGTalk about drawing splines in Shader plugins. And he gave me a link to this site that has Renderman code examples.
      And I'm having some trouble converting it to C4D.
      http://www.hosok2.com/project/st/bezierCurve_kitty.sl.txt
      Renderman shaders use the global variables s&t the same way we use cd->p.x & cd->p.y in C4D shaders. At least that's how I think it works.
      But I can't figure out how to use: ChannelData *cd in these custom methods to replace the s&t Renderman variables.
      C4D is crashing on me if I try to use them in those custom methods. Or anywhere other than the Output() method.
      This is my entire shader plugin code. Based on that RM example.
      Does anyone know how I can convert the s&t variables to work in C4D?
      #include "c4d.h"
      #include "c4d_symbols.h"
      #include "myshader.h"
      #define PLUGIN_ID 1000000
      class MyShader : public ShaderData
        private:
            Real offset;
            Bool enabled;
            Real octives;
            Real bp[288];
            virtual Bool               Init(GeListNode *node);
            virtual    Vector             Output(BaseShader *chn, ChannelData *cd);
            virtual    INITRENDERRESULT   InitRender(BaseShader *sh, const InitRenderStruct &irs);
            virtual    void               FreeRender(BaseShader *sh);
            static NodeData *Alloc(void) { return gNew MyShader; }
      Real isInLine(Real p1x, Real p1y, Real p2x, Real p2y, Real thickness)
        ChannelData *cd = NULL;         //In RM shaders. s&t are built-in global variables equal to: cd->p.x & cd->p.y in the C4D SDK
        Real s = cd->p.x;               //But C4D crashes if I use ChannelData here to try to convert the RM variables s&t to C4D compatible values!!!
        Real t = cd->p.y;               //How can I convert s&t in this RM code to work in a C4D shader plugin?
        Real out = 0;
        Real halfThickness = thickness/2;
        Real ang = 0;
        if(p2x-p1x == 0)ang = 0;
        if(p2y-p1y == 0)ang = 90;
        else ang = atan((p2x-p1x)/(p2y-p1y));
        Real centerLineT = (t - p1y) * tan(ang);
        Real s1 = s - p1x;
        Real cuttingSA = ((1-s +p2x )*tan(ang) - tan(ang))+p2y;
        Real cuttingSB = ((1-s +p1x )*tan(ang) - tan(ang))+p1y;
        Real lineboarderA= halfThickness / cos(180-ang) + centerLineT;
        Real lineboarderB= centerLineT-(halfThickness / cos(180-ang));
        if(s1>lineboarderA && s1<lineboarderB)
            if(p1y - p2y>0)
                if(t>cuttingSA && t<cuttingSB) out = 1;
                else
                    if(t<cuttingSA && t>cuttingSB) out = 1;
        return out;
      Real isInOval(Real x, Real y, Real radius)
        Real inOval = 0;
        if(pow(s-x,2)+pow(t-y,2) < pow(radius,2))inOval = 1;
        return inOval;
      Real isInLine(Real x, Real y, Real thickness)
        return 1;
      Real bezier(Real i, Real a, Real b, Real c, Real d)
        Real B = pow((1-i),3)*a + 3*i*pow((1-i),2) * b + 3*pow(i,2)*(1-i)*c + pow(i,3)*d;
        return B;
      Real isInbezier(Real p0[2],Real p1[2], Real p2[2], Real p3[2], Real thickness, Real pointRate)
        Real out = 0.5;
        Real b[2];
        Real prevX = 0;
        Real prevY = 0;
        Real i=0;
        Real addV = pointRate;
        for(i = 0; i < 1; i += addV)
            b[0] = bezier(i,p0[0],p1[0],p2[0],p3[0]);
            b[1] = bezier(i,p0[1],p1[1],p2[1],p3[1]);
            if(isInOval(b[0],b[1],thickness)) out = 1;
            if( i != 0)
                prevX = bezier(i-addV,p0[0],p1[0],p2[0],p3[0]);
                prevY = bezier(i-addV,p0[1],p1[1],p2[1],p3[1]);
                if(isInLine(b[0],b[1],prevX,prevY,thickness * 2))out = 1;
        //Last Point
        if(isInOval(p3[0],p3[1],thickness)) out = 1;
        if(isInLine(p3[0],p3[1],b[0],b[1],thickness * 2)) out = 1;
        return out;
      Bool MyShader::Init(GeListNode *node)
        BaseContainer *data = ((BaseShader* )node)->GetDataInstance();
        data->SetReal(OFFSET, 0.5);
        data->SetReal(OCTIVES, 0);
        data->SetBool(ON_OFF, FALSE);
      ///////////////////////Data Block//////////////////////////
      bp[0] = 0.357295;bp[1] = 0.307384;bp[2] = 0.319145;bp[3] = 0.291199;bp[4] = 0.248626;bp[5] = 0.262298;bp[6] = 0.223193;bp[7] = 0.283107;
      bp[8] = 0.223193;bp[9] = 0.283107;bp[10] = 0.197759;bp[11] = 0.303916;bp[12] = 0.181575;bp[13] = 0.369812;bp[14] = 0.216256;bp[15] = 0.426458;
      bp[16] = 0.467121;bp[17] = 0.294667;bp[18] = 0.423191;bp[19] = 0.290043;bp[20] = 0.380416;bp[21] = 0.294667;bp[22] = 0.357295;bp[23] = 0.307384;
      bp[24] = 0.230129;bp[25] = 0.406804;bp[26] = 0.207008;bp[27] = 0.45189;bp[28] = 0.166546;bp[29] = 0.538594;bp[30] = 0.211632;bp[31] = 0.641484;
      bp[32] = 0.211632;bp[33] = 0.641484;bp[34] = 0.256718;bp[35] = 0.744374;bp[36] = 0.373482;bp[37] = 0.765181;bp[38] = 0.515675;bp[39] = 0.755933;
      bp[40] = 0.515675;bp[41] = 0.755933;bp[42] = 0.65787;bp[43] = 0.746685;bp[44] = 0.760759;bp[45] = 0.709693;bp[46] = 0.787349;bp[47] = 0.622988;
      bp[48] = 0.787349;bp[49] = 0.622988;bp[50] = 0.813937;bp[51] = 0.536283;bp[52] = 0.805845;bp[53] = 0.468076;bp[54] = 0.761915;bp[55] = 0.413741;
      bp[56] = 0.586759;bp[57] = 0.299223;bp[58] = 0.570023;bp[59] = 0.277627;bp[60] = 0.548427;bp[61] = 0.288424;bp[62] = 0.540868;bp[63] = 0.304081;
      bp[64] = 0.540868;bp[65] = 0.304081;bp[66] = 0.533307;bp[67] = 0.319739;bp[68] = 0.534929;bp[69] = 0.343494;bp[70] = 0.567862;bp[71] = 0.344574;
      bp[72] = 0.686642;bp[73] = 0.341335;bp[74] = 0.706078;bp[75] = 0.335396;bp[76] = 0.723894;bp[77] = 0.348894;bp[78] = 0.720656;bp[79] = 0.36671;
      bp[80] = 0.720656;bp[81] = 0.36671;bp[82] = 0.717418;bp[83] = 0.384527;bp[84] = 0.693121;bp[85] = 0.395325;bp[86] = 0.677465;bp[87] = 0.373729;
      bp[88] = 0.4804;bp[89] = 0.375349;bp[90] = 0.503614;bp[91] = 0.395865;bp[92] = 0.545728;bp[93] = 0.398565;bp[94] = 0.578122;bp[95] = 0.373189;
      bp[96] = 0.509013;bp[97] = 0.221477;bp[98] = 0.460964;bp[99] = 0.26197;bp[100] = 0.457184;bp[101] = 0.354832;bp[102] = 0.4804;bp[103] = 0.375349;
      bp[104] = 0.617535;bp[105] = 0.285726;bp[106] = 0.600799;bp[107] = 0.241994;bp[108] = 0.562387;bp[109] = 0.176501;bp[110] = 0.509014;bp[111] = 0.221477;
      bp[112] = 0.674222;bp[113] = 0.312181;bp[114] = 0.699599;bp[115] = 0.290045;bp[116] = 0.75899;bp[117] = 0.278707;bp[118] = 0.777884;bp[119] = 0.305162;
      bp[120] = 0.777884;bp[121] = 0.305162;bp[122] = 0.79678;bp[123] = 0.331617;bp[124] = 0.787601;bp[125] = 0.420161;bp[126] = 0.719034;bp[127] = 0.443376;
      bp[128] = 0.719034;bp[129] = 0.443376;bp[130] = 0.685665;bp[131] = 0.454674;bp[132] = 0.661805;bp[133] = 0.408283;bp[134] = 0.655866;bp[135] = 0.394786;
      bp[136] = 0.607277;bp[137] = 0.264669;bp[138] = 0.644529;bp[139] = 0.250632;bp[140] = 0.703283;bp[141] = 0.216927;bp[142] = 0.730914;bp[143] = 0.233355;
      bp[144] = 0.730914;bp[145] = 0.233355;bp[146] = 0.750891;bp[147] = 0.245232;bp[148] = 0.755209;bp[149] = 0.291664;bp[150] = 0.755209;bp[151] = 0.291664;
      bp[152] = 0.634107;bp[153] = 0.396369;bp[154] = 0.681664;bp[155] = 0.390094;bp[156] = 0.706689;bp[157] = 0.326596;bp[158] = 0.653755;bp[159] = 0.293313;
      bp[160] = 0.576765;bp[161] = 0.318174;bp[162] = 0.559921;bp[163] = 0.355868;bp[164] = 0.576365;bp[165] = 0.403988;bp[166] = 0.634107;bp[167] = 0.396369;
      bp[168] = 0.653755;bp[169] = 0.293313;bp[170] = 0.619208;bp[171] = 0.27159;bp[172] = 0.590079;bp[173] = 0.288375;bp[174] = 0.576765;bp[175] = 0.318174;
      bp[176] = 0.241038;bp[177] = 0.576052;bp[178] = 0.204851;bp[179] = 0.574286;bp[180] = 0.154984;bp[181] = 0.57782;bp[182] = 0.121444;bp[183] = 0.589734;
      bp[184] = 0.248541;bp[185] = 0.633865;bp[186] = 0.211471;bp[187] = 0.638719;bp[188] = 0.178373;bp[189] = 0.653724;bp[190] = 0.164251;bp[191] = 0.662109;
      bp[192] = 0.289583;bp[193] = 0.679759;bp[194] = 0.266635;bp[195] = 0.690792;bp[196] = 0.229565;bp[197] = 0.706681;bp[198] = 0.211913;bp[199] = 0.728745;
      bp[200] = 0.504;bp[201] = 0.657912;bp[202] = 0.5445;bp[203] = 0.657412;bp[204] = 0.541;bp[205] = 0.616912;bp[206] = 0.505;bp[207] = 0.618912;
      bp[208] = 0.505;bp[209] = 0.618912;bp[210] = 0.473984;bp[211] = 0.620635;bp[212] = 0.4635;bp[213] = 0.658412;bp[214] = 0.504;bp[215] = 0.657912;
      bp[216] = 0.755;bp[217] = 0.528912;bp[218] = 0.7865;bp[219] = 0.516412;bp[220] = 0.84;bp[221] = 0.508912;bp[222] = 0.877;bp[223] = 0.512912;
      bp[224] = 0.7705;bp[225] = 0.582912;bp[226] = 0.7915;bp[227] = 0.582912;bp[228] = 0.839;bp[229] = 0.586912;bp[230] = 0.8605;bp[231] = 0.592412;
      bp[232] = 0.7475;bp[233] = 0.643412;bp[234] = 0.7795;bp[235] = 0.650912;bp[236] = 0.8165;bp[237] = 0.656412;bp[238] = 0.8455;bp[239] = 0.673412;
      bp[240] = 0.668582;bp[241] = 0.591615;bp[242] = 0.671942;bp[243] = 0.57873;bp[244] = 0.675023;bp[245] = 0.556324;bp[246] = 0.649815;bp[247] = 0.554643;
      bp[248] = 0.637211;bp[249] = 0.594696;bp[250] = 0.645613;bp[251] = 0.612342;bp[252] = 0.665071;bp[253] = 0.605071;bp[254] = 0.668581;bp[255] = 0.591615;
      bp[256] = 0.649815;bp[257] = 0.554643;bp[258] = 0.636574;bp[259] = 0.55376;bp[260] = 0.626062;bp[261] = 0.571282;bp[262] = 0.637211;bp[263] = 0.594696;
      bp[264] = 0.360082;bp[265] = 0.608615;bp[266] = 0.363442;bp[267] = 0.59573;bp[268] = 0.366523;bp[269] = 0.573324;bp[270] = 0.341315;bp[271] = 0.571643;
      bp[272] = 0.328711;bp[273] = 0.611696;bp[274] = 0.337113;bp[275] = 0.629342;bp[276] = 0.356571;bp[277] = 0.622071;bp[278] = 0.360081;bp[279] = 0.608615;
      bp[280] = 0.341315;bp[281] = 0.571643;bp[282] = 0.328074;bp[283] = 0.57076;bp[284] = 0.317562;bp[285] = 0.588282;bp[286] = 0.328711;bp[287] = 0.611696;
      INITRENDERRESULT MyShader::InitRender(BaseShader *sh, const InitRenderStruct &irs)
        BaseContainer *data = sh->GetDataInstance();
        offset = data->GetReal(OFFSET);
        octives = data->GetReal(OCTIVES);
        enabled = data->GetBool(ON_OFF);
        return INITRENDERRESULT_OK;
      Vector MyShader::Output(BaseShader *chn, ChannelData *cd)
        Vector colors;
        Real px = cd->p.x;
        Real py= cd->p.y;
        Real opacity = 0.3;
        Real thickness = .5;
        Real pointRate = 1;
        for(LONG i=0; i<sizeof(bp); i += 8)
            Real p1[2],p2[2],p3[2],p4[2];
            p1[0] = bp[i];
            p1[1] = bp[i+1];
            p2[0] = bp[i+2];
            p2[1] = bp[i+3];
            p3[0] = bp[i+4];
            p3[1] = bp[i+5];
            p4[0] = bp[i+6];
            p4[1] = bp[i+7];
            if(isInbezier(p1,p2,p3,p4,thickness,pointRate) == 1) opacity = 1;
        //These are RM opacity and color variables
        //Oi = Os * opacity;
        //Ci = Cs * Oi;
        //I have to somehow convert them into C4D compatible variables
        //I'm still not sure how to do that properly??
        Vector Oi = opacity;
        colors = colors * Oi;
        return colors;
      void MyShader::FreeRender(BaseShader *sh)
      Bool RegisterShaderPlugin(void)
        return RegisterShaderPlugin(PLUGIN_ID,GeLoadString(IDS_MY_SHADER),0, MyShader::Alloc,"myshader",0);
        On 20/03/2014 at 15:41, xxxxxxxx wrote:
        Well, if this is your working code, it crashes because you are using a null pointer in two functions, IsInOval and IsInLine. You're just setting cd to null then using it straight away. You will have to pass a pointer to cd from Output, then at least it shouldn't crash.
          On 20/03/2014 at 20:20, xxxxxxxx wrote:
          Hi Steve.
          I have no idea how to do that.
          ChannelData *cd is being created inside of the Output() method and it works fine being created there for some reason.
          And usually when something is created that way I can also create an instance any other place in my plugin too. But in this case I can't.
          Are you saying that in my custom methods I have to create an instance of ChannelData that's a pointer to the pointer. That's in the Output method?
          Or
          Are you saying that in my custom methods I have to create an instance of ChannelData that's a reference to the pointer that's in the Output method?
          Lol.
          I'm lost.Confused
            On 21/03/2014 at 00:21, xxxxxxxx wrote:
            The pointer to a ChannelData isn't being created inside Output(), it's passed there by Cinema when it calls Output() at render time. So it works then, of course.
            In your functions you are declaring a *cd then setting it to null then using it to access a member variable, so Cinema will immediately crash.
            When you call isInBezier() you will need to pass the cd pointer Output() received, then pass that to the other two function when you call them.
              On 21/03/2014 at 09:19, xxxxxxxx wrote:
              I know the pointer I've got is NULL and needs to be pointed to something else.
              But in this case. I don't know what that something else is that I have to point ChannelData at?
              I'm trying to figure what that is. Possibly maybe BaseShader?
              And I'm also wondering if it would be smarter (or even doable) to use a class member variable of ChannelData here?
              That way the ChannelData  pointer can be written just once, and then used in any methods I want without writing a new copy in each custom method.
              But I don't know what I need to do this.
              All I've  got so far is ChannelData = NULL;
              I know I need to do something more with ChannelData. But I don't know what that is.
              Edit-
              I think I can use ChannelData in my custom custom methods like this:
              ** Real MyFunction(blah, blah, blah, ChannelData *cd)**
              But then I'm running into problems with that cd param. when calling to the method from inside another custom method that doesn't have ChannelData in it.
              I really need to get ChanneData to be globally available like s&t are in Renderman shaders.
              I assume the best place would probably be as class members.
              But I can't figure out how to it.
                On 21/03/2014 at 11:42, xxxxxxxx wrote:
                Well. I got it to run by adding ChannelData *cd my custom methods.
                I would still prefer not to do that and have cd be global. But at least it runs now.
                Now the problem is it doesn't draw the corrects spline shape.
                It's supposed to draw the face of a cat using splines. But all I get is a white sphere on a black background.
                Obvious still a lot of things that aren't converted correctly.
                Trying to convert RM shader code to C4D shader code is really frustrating.!Ouch[URL-REMOVED]
                #include "c4d.h"
                  private:
                      Real offset;
                      Bool enabled;
                      Real octives;
                      Real bp[288];
                Real isInLine(Real p1x, Real p1y, Real p2x, Real p2y, Real thickness, ChannelData *cd)
                  Real s = cd->p.x;
                  Real t = cd->p.y;
                  Real out = 0;
                  Real ang = 0;
                  Real s1 = s - p1x;
                      if(p1y - p2y>0)
                      else
                  return out;
                Real isInOval(Real x, Real y, Real radius, ChannelData *cd)
                  Real s = cd->p.x;
                  Real t = cd->p.y;
                  Real inOval = 0;
                  return inOval;
                  return 1;
                  return B;
                Real isInbezier(Real p0[2],Real p1[2], Real p2[2], Real p3[2], Real thickness, Real pointRate, ChannelData *cd)
                  Real out = 0.5;
                  Real b[2];
                  Real prevX = 0.0;
                  Real prevY = 0.0;
                  Real i=0;
                      if(isInOval(b[0],b[1],thickness, cd)) out = 1;
                      if( i != 0)
                          if(isInLine(b[0],b[1],prevX,prevY,thickness * 2, cd)) out = 1;
                  //Last Point
                  if(isInOval(p3[0],p3[1],thickness, cd)) out = 1;
                  if(isInLine(p3[0],p3[1],b[0],b[1],thickness * 2, cd)) out = 1;
                  return out;
                  Vector colors;
                  Real px = cd->p.x;
                  Real py= cd->p.y;
                  //Colors for the lines and the background
                  Vector black = Vector(0,0,0);   //Lines color
                  Vector white = Vector(1,1,1);   //BG color
                  Real opacity = 0.3;
                  Real thickness = 0.5;
                  Real pointRate = 200.0;
                      p1[0] = bp[i];
                      p1[1] = bp[i+1];
                      p2[0] = bp[i+2];
                      p2[1] = bp[i+3];
                      p3[0] = bp[i+4];
                      p3[1] = bp[i+5];
                      p4[0] = bp[i+6];
                      p4[1] = bp[i+7];
                      if(isInbezier(p1,p2,p3,p4,thickness,pointRate, cd) == 1) colors = white;
                      else colors = black;
                  return colors;
