    python plugin on frame update
    4 Posts 0 Posters 440 Views
      On 03/03/2014 at 06:25, xxxxxxxx wrote:
      Is it possible when i press a button a function is called that keeps checking if the time of timeline is changed. So that i can run an other function every time a frame update is called.
      I want to do this to clone an objects global matrix to another object every time timeline changes.
      I know u can do this with python node or tag but that's not the solution I'm searching for. Or can enable/disable a tag with plugin?
      Greets,
      GiMars
        On 03/03/2014 at 08:28, xxxxxxxx wrote:
        Hi
        This thread touches that problem : http://forums.cgsociety.org/archive/index.php/t-1090235.html
        Bonsak
          On 04/03/2014 at 06:00, xxxxxxxx wrote:
          I got it to work!
          Im using messageData that checks for EVMSG_CHANGE. And made a function that creates a null object with an expresso tag and a python node that is frame dependent that calls c4d.EventAdd() everyframe and that does the job 😄
          Great thread u posted Thanks Bonsak!
            On 04/03/2014 at 06:13, xxxxxxxx wrote:
            Yw 🙂
            -b
