    Color: as many unique color (vectors) as objects?
    11 Posts 0 Posters 1.3k Views
      On 28/02/2014 at 18:18, xxxxxxxx wrote:
      Give this a try.
      It should theoretically generate a ton of unique colors.
      import random
        #Create a list array to hold all of the vector colors
        colors = []
        num_Colors = 100   #<--- Change this number as desired
        #Generate lots of colors values between 0-255 using random
        #Then test to see if the color already exist in the colors list
        #If the color already exists..start the loop over again
        #If the color is not in the list...Add it to the list
        for i in xrange(num_Colors) :
            vec = c4d.Vector(random.randint(0, 255), random.randint(0, 255), random.randint(0, 255))
            if vec in colors: continue
            else: colors.append(vec)
        print colors
        On 01/03/2014 at 13:20, xxxxxxxx wrote:
        Hi ScottA,
        i tried this because your script didn't produce valid color vectors, found some similar script for random colors which had this division by 256 incorporated, don't know if this is the real deal but it gives me colors.
        Anyway i still have trouble to exclude black and white, when the script finds the vec in the list it continues but does not add another value it seems, hence I get index out of range errors.
        any idea?
        def random_unique_colors(howmany) : #Create a list array to hold all of the vector colors
            colors = []
            white = c4d.Vector(1,1,1)
            black = c4d.Vector(0,0,0)
            for i in xrange(howmany) :
                vec = c4d.Vector(random.randint(0, 255)/256.0, random.randint(0, 255)/256.0, random.randint(0, 255)/256.0)
                if vec in colors or vec == white or vec == black: continue
            return colors
          On 01/03/2014 at 14:07, xxxxxxxx wrote:
          Sorry to bother,
          i tried it with 70.000 Objects and not getting nearly as many colors in the list - something is definitely wrong and slow.
          I guess i really need some sort of "step" solution.
            On 01/03/2014 at 15:37, xxxxxxxx wrote:
            If you want values between 0-1 instead of 0-255. Then try it like this:
            import random
              colors = []
                  vec = c4d.Vector(float(random.randint(0, 255)/100.0), float(random.randint(0, 255)/100.0), float(random.randint(0, 255)/100.0))
              print colors
            This is going to be very slow because
            a.) It's generating huge amounts of data
            b.) It's looking through the list for already existing values every iteration of the loop. Which takes longer...depending on how many vectors are in the list.
            I'm sure there's faster more optimized ways to generate large numbers of vectors. I just came up with this code off the top of my head.
            If you don't mind the generated colors being sequential. Simply incrementing the values per loop iteration, and deleting all the random and the "if vec in colors:"  code I used, will speed it up a lot.
            I just assumed that you didn't want the color values to be sequential.
              On 02/03/2014 at 04:59, xxxxxxxx wrote:
              Hi
              If you want to limit the color range it might be easier to start in HSV.
              from random import randint, randrange
              from c4d import utils
                  howMany = 1000
                  colors = []
                  # Change min/max to limit hue range ( degrees )
                  hueMin = 0
                  hueMax = 360
                  # Change min/max to limit saturation range ( % )
                  saturationMin = 0
                  saturationMax = 100
                  # Change min/max lo limit value range ( % )
                  valueMin = 0
                  valueMax = 100
                  for i in xrange(howMany) :
                      h = float(randrange( hueMin, hueMax )) / 360
                      s = float(randrange( saturationMin, saturationMax )) / 100
                      v = float(randrange( valueMin, valueMax )) / 100
                      # Convert hsv to rgb and append new value to list
                      colors.append(c4d.utils.HSVToRGB( c4d.Vector(h, s, v) ))
                  print colors
              I'm not sure if all these colors are completely unique.
              Bonsak
              PS How do i set the line spacing inside the code block?
                On 02/03/2014 at 05:06, xxxxxxxx wrote:
                Thanks for all your answers,
                I came up with a quiet dirty method manipulating a string, but it works good and isn't to slow after all.
                I do not need random! I need unique and well spaced colors because I am trying to code a object visibility plugin.
                def unique_colors(howmany) : #Create a list array to hold all of the vector colors
                    if howmany == 0:
                        return False
                    colors = []
                    step = 999999998 / howmany # 0.999 0.999 0.999 divided by the objectcount
                    largestring = 1000000001 + (step/2) # puts the range in the middle betweeen black and white
                        r = float(str(largestring)[1:-6])/1000
                        g = float(str(largestring)[4:-3])/1000
                        b = float(str(largestring)[7:])/1000
                        colors.append(c4d.Vector(r , g, b))
                        largestring = largestring + step
                    return colors
                  On 02/03/2014 at 12:33, xxxxxxxx wrote:
                  I see. So you need a narrow range of hues, or the full spectrum devided evenly among the members?
                  Bonsak
                    On 02/03/2014 at 13:02, xxxxxxxx wrote:
                    I need full spectrum devided evenly among the members, without black and white to prevent errors with the background.
                    kind regards
                    mogh
                      On 18/03/2014 at 13:57, xxxxxxxx wrote:
                      Still searching for a clean solution,
                      found this but can't implement it
                      http://stackoverflow.com/questions/470690/how-to-automatically-generate-n-distinct-colors
                      kind regards
                        On 10/04/2014 at 03:27, xxxxxxxx wrote:
                        found something:
                        g = itertools.product(range(1,255), repeat=3) # range excluding 0 and 256
                        for x in manycolors:
                            color = g.next()
                        this creates as many colors as often you call g.next()
                        kind regards
