    Marker and Materials
    6 Posts 0 Posters 1.5k Views
      On 08/11/2002 at 07:47, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      How can I get the material belonging to a texture tag? I don´t really know how to use the returned marker that I can get with GetMaterial().
      I guess I have read in the C++ of R8 there are no markers anymore. How does it work for COFFEE now?
      Samir
        On 10/11/2002 at 06:37, xxxxxxxx wrote:
        Markers were used by iterating through all materials and checking if their markers matched. That has now been replaced by BaseLinks. (Not available in C.O.F.F.E.E.)
        I haven't tested if Markers still work in R8. If they don't, then I don't think it's possible to find the material belonging to a texture tag in C.O.F.F.E.E.
          On 10/11/2002 at 06:41, xxxxxxxx wrote:
          Thanks, that helps. It´s not pretty elegant but what shall I do. Hope COFFEE will be updated with the next Cinema 4D update.
            On 09/01/2003 at 07:25, xxxxxxxx wrote:
            is there really no way to get an objects (tags ) material in coffee? I need to get the texture applyed to an obj.
            greetings, Nico
              On 11/01/2003 at 07:08, xxxxxxxx wrote:
              As far as I can tell the markers are still maintained. At least this produces the expected results:
                  main(doc,op)
                    var tag = op->GetFirstTag();
                    println(getclass(tag));
                    var mark = tag->GetMaterial();
                   println(getclass(mark));
                    var mat = doc->GetFirstMaterial();
                    println(getclass(mat));
                    println(mat->GetMarker()->IsEQ(mark));
              So pre R8 methods of getting the material should work. (I.e. looping through all materials checking for the one with the matching marker.)
                On 27/03/2005 at 07:12, xxxxxxxx wrote:
                here i get invalid file operation on export:
                (error must be in ...GetMarker... command)
                WriteMatList(obj,dok) {
                 var tag,matname,mark,mat;
                 for (tag = obj->GetFirstTag(); tag; tag=tag->GetNext())
                  if (instanceof(tag,TextureTag))
                   mark=tag->GetMaterial();
                   for(mat = dok->GetFirstMaterial(); mat; mat=mat->GetNext())
                    if (mat->Getmarker()->IsEQ(mark)) matname=mat->GetName();
                 if (matname==NULL) matname="";
                 return matname;
