    Picture viewer
    2 Posts 0 Posters 948 Views
      On 07/11/2002 at 08:33, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      how can I get several layers into  the picture viewer ?
      like the multi pass  tools do.
      i tried  something like  this
      for (LONG n=0;n<20;n++)
      bmp->AddChannel(false,false);
      ok there seems to be a limit on a bitmap of  5 alphas which show up when i do ShowBitmap(bmp) ,  this is not really  what im after.
      Multipass sends a specific channel with a name , which can also be toggled on/off , so id like to know how i can do the same kind of thing.
      if this is not possible , is there any way to find out how the parts of muilt pass are put together (multi layer display) so i could maybe put the image together myself ?
      also , if i start ther picture viewer from a video post plugin , cinema will freeze.ive tried all sorts of things to stop this , even built my own dialog and try to launch that , but it seems not possible to launch a dialog from a video post plugin. Is this correct?
      thanks for any help.
      cheers
      Paul
        You should check out how the videopost examples do it. Look for VPBUFFER_ALPHA and AllocateBuffer().
        From the inner loop? No, that is forbidden since that part of the code is threaded and multi processor enabled.
