    Adding Pose Target
    4 Posts 0 Posters 360 Views
      On 11/02/2014 at 15:00, xxxxxxxx wrote:
      I am trying to dynamically add and set pose morph to a morph tag. I've been able to add blank poses to the tag using pose.AddMorph() but I can not seem to figure out how to set the target of that added morph.
      Any ideas?
        On 11/02/2014 at 18:35, xxxxxxxx wrote:
        I figured it out, I didn't realize there was a CAMorph class.
          On 28/09/2014 at 08:31, xxxxxxxx wrote:
          Hi Shawn,
          as you managed it, do you like to post a small snippet?
          I actually tried:
                MoTag = op.MakeTag(c4d.Tposemorph)
                MoTag[c4d.ID_CA_POSE_POINTS]=True
                BaseMo= MoTag.AddMorph()
                Pose_1= MoTag.AddMorph()
                BaseMo.SetMode(doc, MoTag,c4d.CAMORPH_MODE_FLAGS_EXPAND, c4d.CAMORPH_MODE_REL)
                Pose_1.SetMode(doc, MoTag,c4d.CAMORPH_MODE_FLAGS_EXPAND, c4d.CAMORPH_MODE_REL)
                MoTag.InitMorphs()
                BaseMo.Apply(doc, MoTag, c4d.CAMORPH_DATA_FLAGS_ALL)
                Pose_1.Apply(doc, MoTag, c4d.CAMORPH_DATA_FLAGS_ALL)
                #it´s not working with
                #     Pose_1.SetBit(c4d.BIT_ACTIVE)
                #     print Pose_1[c4d.ID_CA_POSE_TARGET]
                #     print Pose_1.GetFirst()
          But, no success!
          Thanks in advance
          Martin
            On 29/09/2014 at 18:37, xxxxxxxx wrote:
            You can't set the active pose morph via python and is only available through C++ :frowning2:
